Does anyone know how to configure a Siemens 802sl 4th a is the parameter is erased and we cannot run the 4th axis anymore thanks!
Ok, so the parameters on 828dsl (pretty certain 802 are the same) are as follows:
Setup - machine data - drive machine data - axis machine data
using vertical soft key axis + / axis - select 4th axis . You then need to set MD30130 to 1 & MD30240 to 1, NCKPO (or complete power down) to activate datas. As SL sinamics drives are drive cliq, they should self configure, you may need to power down again.
Thanks control concern but our 4th axis did not come with the machine it was bought separately I don’t think it has a drive cliq and the Taiwanese guy configured it but now it’s been erased but I will try what you said.
