586,104 active members*
3,431 visitors online*
Thread: Need help
    Need help
    Does anyone know how to configure a Siemens 802sl 4th a is the parameter is erased and we cannot run the 4th axis anymore thanks!
    Jun 2017
    12
    Re: Need help
    Ok, so the parameters on 828dsl (pretty certain 802 are the same) are as follows:
    Setup - machine data - drive machine data - axis machine data
    using vertical soft key axis + / axis - select 4th axis . You then need to set MD30130 to 1 & MD30240 to 1, NCKPO (or complete power down) to activate datas. As SL sinamics drives are drive cliq, they should self configure, you may need to power down again.
    Re: Need help
    Thanks control concern but our 4th axis did not come with the machine it was bought separately I don’t think it has a drive cliq and the Taiwanese guy configured it but now it’s been erased but I will try what you said.
