586,060 active members*
3,992 visitors online*
IndustryArena Forum > Community Club House > Machinist Hangout > How to use Z Axis Pre-setter Tool Setter?
    Could someone please explain how to use this z axis setter? And, it has two set screws underneath but what do they do?
    Mike
    Oct 2004
    178
    Re: How to use Z Axis Pre-setter Tool Setter?
    the bar is for calibration. Lay it across the piston and the side of the setter, pushing it all the way down. The dial indicator should read zero. Put the setter on top of your part and bring the tool down until the dial reads zero. Knowing the height of the tool setter (usually 2" or 50 mm) you now have your tool height. Enter the tool setter height in the Z column of the G54 offset table and you're good to go.
  1. Tool Setter Macro for M-V60C and Metrol Setter
    By mitshack in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 02-02-2013, 12:08 PM
  2. How to choose a Z axis setter / Presetter tool
    By gtxkid in forum Want To Buy...Need help!
    Last Post: 12-09-2012, 04:09 AM
  3. MFG CNC Machine Z-Axis Zero Tool Setter Pro -MADE IN THE USA-
    By KLW-MFG in forum News Announcements
    Last Post: 01-20-2012, 10:07 PM
  4. Tool setter macro for M-V60C and Metrol setter
    By mitshack in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 10-06-2008, 02:38 PM
