586,110 active members*
3,325 visitors online*
    Feb 2005
    117
    Mach 3 control of printer
    I am looking for information with regards to using Mach 3 to control a 3d printer. I am
    starting a build and am in the design phase looking for information to use Mach to control
    4 axis (x , y, z, A ).
    The 4th axis will be used to drive the extruder.
    If anyone could direct me to a source of information would be appreciated.
    Thank you
    Johnd
    Apr 2013
    1899
    Re: Mach 3 control of printer
    In my opinion it is better to build it with a real 3D printer controller. That way you can also use an SD card to transfer the files and there are plenty free resources to use. You will have issues with controlling the heat also with Mach, as well as the fans. It is not just 4 steppers you need to handle, 3D printing is more complicated and Mach is not made for that purpose.
  1. Mach 3 and Windows 7 Printer Port
    By kennected in forum Mach Software (ArtSoft software)
    Last Post: 01-14-2016, 03:05 PM
  2. He 3D AL230 3d printer kit - LCD Control Panel RAMPS 1.4
    By jiahaiqing in forum For Sale Only
    Last Post: 06-29-2015, 05:56 AM
  3. THC for Mach3 - full external Z control vs Mach Z control
    By Beefy in forum CNC Plasma / Oxy Fuel Cutting Machines
    Last Post: 04-28-2015, 10:45 PM
  4. Printer Port relay control
    By Sieg in forum CNC Machine Related Electronics
    Last Post: 12-08-2007, 08:39 PM
  5. Printer control boards for CNC????
    By thuffner3 in forum CNC Machine Related Electronics
    Last Post: 07-04-2005, 01:09 AM
