I just put together my enclosure with the new Masso controller after upgrading from Mach3. I (thought I) copied the wiring I had on the old C41 cnc4pc board to the Adlee spindle controller, but I can't get it to spin at all. I have NO idea whats going on. Feel free to check the dumb stuff because I've only worked on this between 11pm and 130 am this week because it was the only time I had.
The controller displays RPM when I input M3 S2000 as if it should be working, but there's NOTHING happening on the motor side. Fluke shows good 249 VAC coming in, but i'm apprehensive about checking output power because there's a warning in the manual about checking the output cabling (labeled U, V, W) as it could cause damage. Below is a picture of the page showing the pinout, as well as a link to the manual and the masso page about connecting a spindle.
Adlee controller: https://webbuilder5.asiannet.com/300...2%20Driver.pdf
Masso controller: https://masso.com.au/docs/masso-cnc-...dle-connector/
