586,119 active members*
3,539 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > Chinese 2.2Kw Remote POT help
    Nov 2011
    51
    Trying to get a remote POT working and run into a little problem.
    I have a 10K Ohm POT dial wired into my VFD and the settings changed on my VFD to "remote" and I have somewhat of an issue. The remote POT is working but with the remote POT turned all the way down it keeps the spindle rotating at the lowest setting which is 6000 RPM when I turn the pot half way it goes up to about 12500RPM and when i turn the remote POT all the way up it goes back down to 6000 RPM.
    Anyone know why it is doing this and not going all the way to 24000RPM when I turn the remote POT to the max setting?
    here is a pic of how I have the remote pot Wired up. see attached
    Nov 2011
    51
    Re: Chinese 2.2Kw Remote POT help
    nobody ????
    Have you measured the voltage coming from the pot?
    15362
    Quote Originally Posted by msdeltaguy View Post
    Do you have the 10v connected to the Pot and ACM to the other end, then the Wiper connected to VI
    Parameter PD070=0 and PD002=1
    Jumper set correct 1-2
    Mactec54
  1. second/remote dro
    By charliex in forum FlashCut CNC
    Last Post: 02-27-2016, 11:12 PM
  2. VF-5 Remote Jog issues
    By Cleschak in forum Haas Mills
    Last Post: 07-23-2012, 12:52 PM
  3. Chinese Mill + Chinese accesory + Newbee = Problem
    By csaw in forum Benchtop Machines
    Last Post: 01-24-2010, 05:39 PM
  4. Wii remote with CNC?
    By DeepWoods in forum CNC Machine Related Electronics
    Last Post: 09-14-2008, 05:07 PM
  5. Remote operation
    By becikeja in forum Machines running Mach Software
    Last Post: 06-08-2007, 01:58 AM
