586,055 active members*
4,176 visitors online*
    Glass engraving not going well
    Hello, I have a chinese 150W CO2 laser. To engrave glass I use 400 mm/s speed and 40% power. I tried with interval 0.1 mm and 0.06 mm.
    After engraving the graphic has particles of glass stuck to it which need to be removed manually. Is there some way to solve this?
    Nov 2015
    371
    Re: Glass engraving not going well
    I assume you have a DC laser. This type of lasers is used primarily for cutting, not so much for engraving. Can you post some pictures of the problem and the machine?
    Nov 2012
    492
    Try lower power faster speed. 150 is really to much power for engraving. Most people have 60 to 80 watts for engraving. The high power tubes hard hard to dial down for a decent engraving.Glass needs lower pwr faster spd
  1. Glass engraving
    By yasam2002 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 08-30-2012, 09:08 AM
  2. Glass Engraving
    By SHADOW042 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 12-14-2011, 12:38 PM
  3. Engraving Glass w/ CNC
    By mredican in forum Glass, Plastic and Stone
    Last Post: 04-28-2011, 11:02 AM
  4. Engraving (glass and acrylic)
    By fibonacci in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 12-02-2010, 11:47 PM
  5. Glass engraving
    By julianh in forum Uncategorised MetalWorking Machines
    Last Post: 08-11-2009, 02:10 AM
