586,065 active members*
4,327 visitors online*
IndustryArena Forum > MetalWorking Machines > Novakon > Retrofit of ESS to MN-200
    Feb 2012
    26
    hi all,
    have a question for those that still have an NM-200.
    I am trying to remotely help a friend that has a V2 of the machines and has had to upgrade the onboard PC due to some failure or another. In the process he has installed an ESS and despite the XYZ axes being fine, he is struggling to figure out the spindle motor. The motor and driver of it is the early Sangmutan.
    Specifically, do you need to select PWM mode or step and dir mode in Mach and how would that translate to the ESS config screen.
    If anyone has an XML they would be able to share, please do so.
    Thanks in advance.
    Dec 2009
    594
    Re: Retrofit of ESS to MN-200
    Here's my XML
    Attached Files Attached Files
    Feb 2012
    26
    Thanks Kvom!
    I will get the guy to try it.
    Do you remember if you have made any changes to the pin connections?
    Dec 2009
    594
    My mill has the Novakon control box (CD100) that I've never made any hardware changes to. Parallel port interface.
    That said I switched to PathPilot where PP and the Mesa card are in a separate computer but I still use the CD100 to house the BoB and drivers, connected with 25 pin cable.
  1. RETROFIT CONTROL & RETROFIT PROJECTS WITH NCT CNC SYSTEM
    By NCT201 in forum Machinery Manuals / Brochures
    Last Post: 07-26-2016, 11:24 AM
  2. Millpwr Retrofit-Retrofit on Bridgeport
    By pofo in forum Bridgeport / Hardinge Mills
    Last Post: 03-08-2010, 12:19 AM
  3. Replies: 31
    Last Post: 11-27-2008, 06:55 AM
  4. camsoft retrofit to a anilam crusader retrofit
    By bowlingmac in forum CamSoft Products
    Last Post: 07-25-2008, 03:00 AM
