586,308 active members*
3,385 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > Transfer Files from/to pc machine
    May 2018
    74
    Hello, I would like to know how to transfer files from pc to machines and from machines to pc. We have some OKUMA LC20 osp 5000L-G, LB15 osp 5020L and LB12 OSP 500L-G.What do I need for my laptop? Software, cables...parameters.....? No one in my company knows how to transfer files to/from pc and machine.Thanks for your help
    Apr 2006
    822
    Re: Transfer Files from/to pc machine
    Hi dodochau,
    For many years now I have used the communications program from DNC4U. see https://www.dnc4u.com/
    VERY simple to setup and use.
    Also reasonably priced as well.
    The person behind the software is also very helpful.
    The software does have a trial period where you can use it to see how it fits in for you.
    I have used the software on everything from Win XP through Win 10 so is compatible across all usual systems.
    Wiring diagram is in the help file within the software.
    I have attached a couple of files, one covering the parameter settings that I have used on our machines of the same vintage and one from Okuma on Serial Comms.
    Cheers
    Brian.
    May 2018
    74
    THANK YOU.
    Quote Originally Posted by broby View Post
    Hi dodochau,For many years now I have used the communications program from DNC4U. see https://www.dnc4u.com/VERY simple to setup and use.Also reasonably priced as well.The person behind the software is also very helpful.The software does have a trial period where you can use it to see how it fits in for you.I have used the software on everything from Win XP through Win 10 so is compatible across all usual systems.Wiring diagram is in the help file within the software.I have attached a couple of files, one covering the parameter settings that I have used on our machines of the same vintage and one from Okuma on Serial Comms.CheersBrian.
    Jul 2016
    19
    [QUOTE=broby;2193274]Hi dodochau,
    Hi broby,
    I tried your parameter settings and cable spec but it don´t work, what settings do you use in DNC4U? I´m using the same program. The machine got OSP 5000L-G
    Aug 2009
    1573
    Quote Originally Posted by Beefheart View Post
    ..this thread may help you
    https://www.cnczone.com/forums/okuma...-software.html
  1. TRANSFER FEATURES BETWEEN DIFFERENT FILES?
    By Tolyatti in forum FeatureCAM CAD/CAM
    Last Post: 10-20-2016, 01:20 PM
  2. Xml files and license transfer?'s
    By dan3676 in forum Mach Software (ArtSoft software)
    Last Post: 11-21-2014, 08:43 PM
  3. mycenter hx250iF How to transfer files?
    By carlosram in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 03-19-2011, 01:02 AM
  4. How to transfer files to 840D?
    By abdous in forum SIEMENS -> Sinumerik 802D/808D/810D/828D/840D
    Last Post: 08-14-2010, 07:22 AM
  5. How to Transfer Large Files?
    By adsxy in forum Uncategorised CAD Discussion
    Last Post: 09-13-2008, 12:35 PM
