586,043 active members*
3,587 visitors online*
IndustryArena Forum > Events, Product Announcements Etc > News Announcements > Advice/Looking for Info on Micro/Jewerly End Mills
Results 1 to 2 of 2
    Jun 2018
    Hi all, first-time poster.
    I've been learning by myself with my Universities Bantam Tools CNC Machine, mostly milling PCBs in FR-1 (Copper and Fiber Glass). I've been wanting to use smaller ICs on my PCBs, so I bought some 0.2 and 0.3mm Flat End Mills from China that I knew weren't going to be great given their price, but wanted to just experiment. These smaller bits broke immediately on the FR-1 I was trying to mill, so before I destroyed all ten wanted to know if anyone had knowledge, documentation, etc on using these types of smaller "jewellry" end-mills.
    More than anything I want to know if my speeds and feeds sound right. I've never had to calculate them myself, and can't find any suggested speeds for such small end-mills. For the 0.3mm 8-Flute End-Mill I'm using the following auto generated values:
    Feed rate: 144.00 mm/min
    Plunge Rate: 12.00mm/min
    Spindle Speed: 12000rpm
    Stepover: 15.00%
    I'm going to fathom a guess I should just spend the extra money for end-mills with fewer flutes (like 2), as it makes for a very lengthy bit that seems too fragile.
    Thanks for the help.
    Dec 2013
    5717
    Re: Advice/Looking for Info on Micro/Jewerly End Mills
    Try slowing down your feed, a lot. The work up from there
    Jim Dawson
    Sandy, Oregon, USA
  1. need advice/info on CNC mills with 4th axis swivel head
    By adrenaLinas in forum Want To Buy...Need help!
    Last Post: 02-19-2014, 07:41 AM
  2. micro end mills in Canada ???
    By George777 in forum CNC Tooling
    Last Post: 06-15-2010, 05:32 PM
  3. Micro end mills and tolerance - HINT
    By etzz in forum MadCAM
    Last Post: 02-23-2009, 09:37 PM
  4. Micro-Swing info....
    By Dave Dahl in forum Uncategorised MetalWorking Machines
    Last Post: 03-01-2008, 02:37 PM
  5. Cutting wax models for jewerly
    By lpz in forum Machine Created Art
    Last Post: 04-29-2007, 09:40 PM
