586,076 active members*
3,757 visitors online*
    Jun 2018
    360 spindle cooling malfunction alarm in yellow
    Having an issue with this alarm. Changed out spindle cooling pump and cleaned radiator. Still getting alarm. Fan is running fine. Any ideas?
    Sep 2017
    139
    Re: 360 spindle cooling malfunction alarm in yellow
    Any alarm indication on the spindle drive 7 segment display?
    You may also go to diagnosis alarm page and give the complete alarm details along with numbers mentioned in the bracket, which will help to find the exact cause.
    Also under diagnosis --> SPindle drive, check what is written against LED status
  1. Spindle cooling with PC Liquid cooling system
    By enforcer in forum DIY CNC Router Table Machines
    Last Post: 02-07-2012, 09:02 PM
  2. Mazak T32-3 Alarm 015 System Malfunction
    By reillyeng in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 05-27-2011, 02:24 PM
