586,072 active members*
4,729 visitors online*
IndustryArena Forum > CNC Electronics > Servo Motors / Drives > YASKAWA SERVOPACK SGDB-10VD
    I have YASKAWA SERVOPACK SGDB-10VD
    i need to controll it with +-10v controller , can anyone tell me if this type of driver support +-10v analog input and if you have wire diagram .
    thanks
    15362
    Re: YASKAWA SERVOPACK SGDB-10VD
    Quote Originally Posted by bujar.gashi View Post
    thanks
    Linux CNC Control with a Mesa board https://store.mesanet.com/index.php?...tegory&path=83
    There are others this is a starting point
    Yes this drive can do +/- 10v for Speed / Torque control, or it can do Step / Dir for Position Control, the PDF files are to large to up load, but you can find them here
    https://www.yaskawa.com/downloads?p_...dportlet_cur=2
    Mactec54
    Thanks for quick response.
    Can you tell ports that will suport step / dir , do you have schema , i need this for cnc wood machinen.
    15362
    The information is in the manual I posted the link to, you have to down load the PDF files, the PDF files are too large to post here, so you have to down load them, and you will have everything you need to get them connected and running
    Mactec54
  1. Swap yaskawa sgdb-15adg for a sgdb-10adg
    By gzero in forum Servo Motors / Drives
    Last Post: 08-24-2016, 04:55 AM
  2. Yaskawa servopack
    By NeubieCNC in forum Servo Motors / Drives
    Last Post: 07-03-2016, 06:03 AM
  3. Need replacement for yaskawa sgdb-10adg
    Last Post: 02-23-2015, 01:54 PM
  4. Yaskawa servopack
    By hotrob1 in forum Want To Buy...Need help!
    Last Post: 01-26-2011, 03:42 PM
  5. Cable for programming Yaskawa SGDB Parameters
    By grc in forum Servo Motors / Drives
    Last Post: 08-30-2010, 03:00 AM
