586,065 active members*
4,312 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Baruffaldi Turret On 10" Megabore Fanuc 18i-TB
Results 1 to 11 of 11
    Jun 2018
    4
    Post Baruffaldi Turret On 10" Megabore Fanuc 18i-TB
    Hi can anyone help me on my 10" Megabore Fanuc 18i-TB.
    Baruffaldi turret with DMS-08BF drive it wasnt indexing and turned out the motor is faulty so they replaced the motor and could only index one tool at a time anything more would through up a alarm turret zero search time out, we installed the new drive and now doesnt index at all and give a 4.1 alarm on drive and same alarm turret zero search time out please help
    Dec 2012
    395
    Jun 2018
    4
    Hi Thank you will it have the zero position procedure on the DMS-08BF?
    Jun 2018
    4
    They dont have the zero set procedure do you know where i Can download it?
    Dec 2009
    953
    Re: Baruffaldi Turret On 10" Megabore Fanuc 18i-TB
    Quote Originally Posted by KyleC1 View Post
    it is a beta drive for the turret?
    if yes,u should have a screen special for this drive.
    May 2016
    526
    You will possibly have to go through the PMM parameters
    Who are you, where is installed your Machine? I can send you all technical info for easy to solve, and reserved procedure for to check, for diagnostic, and for alignment RESOLVER/MOTOR.
    Get me also before Label on servomotor, and Label on servodrive DMS...
    Quote Originally Posted by zavateandu View Post
    Not exist BETA DRIVE on this machine Megabore, there is a CUSTOM PROCEDURE for to install and for to SET after CHANGING SERVOMOTOR B5602p or Proper DRIVE DMS. Only need Serial N. of Turret and i can specify exactly procedure.
    Jun 2021
    6
    Hi MEN
    All these links are unavailable. Do you have the list of alarms, please give me
    I use this drive model according to the attached images
    I recently had a problem and the error 9.2 is displayed on the drive
    Please advise how to fix this error
    Jun 2021
    6
    Jun 2021
    6
    I use this drive model Baruffaldi turret Type : DMS-08BF
    Please advise how to fix this error Do you have the list of alarms, please give me.
  1. Help Fanuc OT-A Turret (Baruffaldi RH80) lost
    By gerry1960 in forum Fanuc
    Last Post: 01-12-2016, 11:00 PM
  2. Replies: 5
    Last Post: 09-22-2014, 04:05 AM
  3. Baruffaldi Turret
    By Al_The_Man in forum DNC Problems and Solutions
    Last Post: 07-07-2012, 09:17 PM
  4. Fanuc 18t Turret alarm "1110"
    By senna95 in forum Fanuc
    Last Post: 10-18-2006, 05:03 PM
