586,070 active members*
3,442 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Requested home axis switch is active please.. please fix then home...................
    Jun 2018
    4
    Ok I've got a good one for you! Mach 3 version R3.043.066. Today, after firing up the machine, I ran an ref all home. Put a new bit in the holder, put that in the head and jogged to z zero.
    Adjusted the tool offset in settings then ran auto set tool length offset, and shut the program down. Restarted mach, and ref all home. When referencing, Z and X referenced, as did the first Y sensor, but the second y sensor (which is labeled as A in config, just kept on going like Forest Gump. The sensors are all illuminated, and while the Ya sensor passed over the bolt, the light turned off, even though the gantry kept on going. I took screen shots, and made a video. While y was traveling towards the sensor, the following text displayed. "requested home axis home switch is active..please fix them home"
    I am a total noob at this. Been operating this machine for 3 years now, and each problem is a whole new world to me. This one seems to have popped up our of no where, and doesn't seem to be caused by things I did. Here is a video of me looking through some things... https://youtu.be/-pztbDToHvc
    Attached Thumbnails Attached Thumbnails soft limits.PNG   settings.jpg   output signals.PNG   motor outputs.jpg
    Jun 2018
    4
    Re: Requested home axis switch is active please.. please fix then home...............
    I just switched the hall sensors over to the opposite sides of the gantry, and the same problem happened on the opposite side of the gantry, so I believe now the problem is solved. Gonna go overnight Saturday delivery on this one.
    Jun 2018
    4
    Actually, strange enough, the problem was that the tool touch off sensor was stuck. Pulled it up and re set both sensors over to the opposite sides, and it worked. Jeez this has been a nice problem to solve.
  1. VF-0 Z Axis Won't Home to Limit Switch - Help!
    By roofis27 in forum Haas Mills
    Last Post: 11-18-2013, 10:55 PM
  2. The Z Axis Home Switch Problem
    By wickedweed in forum Maintenance DIY Discussion
    Last Post: 04-06-2012, 03:16 AM
  3. Optical Home Switch circuit design - feedback requested
    By mhackney in forum CNC Machine Related Electronics
    Last Post: 01-26-2012, 09:19 PM
  4. X2 Z axis home switch mounting.
    By TXFred in forum Benchtop Machines
    Last Post: 02-19-2011, 02:54 PM
  5. 1 or 2 switch z home axis with thc and mach3?
    By sax in forum Waterjet General Topics
    Last Post: 12-21-2010, 03:22 PM
