586,069 active members*
3,307 visitors online*
IndustryArena Forum > CAM Software > Vectric > 4th Axis cutting DSP A18 Vectric problem
    Feb 2007
    4
    Hello,
    I am new to 4th axis rotary cutting, I have a large bed machine with a rotary cutter down the Y axis, using a A18 DSP. I can create toolpaths in Aspire but whatever post processor I use wont work, need X to A, have tried all the ones.
    Any advice?
    Re: 4th Axis cutting DSP A18 Vectric problem
    Can you elaborate on what problems you are seeing? What doesn't work?
    Feb 2007
    4
    Hi Ger21,
    Yeah, sorry, didn't give much detail.
    I create a file in vectric using the wrapping gadget. All setup correctly, with right axis, with origin on centre. I create a toolpath and export as a Mach 2/3-Wrapx2a atc(mm).txt file (I have tried all the others that wrap x to a).
    I set the machine up, and zero all the axis on the centre point, then move the Y axis down the material and zero that. When I run the software I get soft limits. see picture.
    Attachment 396240
    You need to determine what i the g-code is causing the softlimit error.
    It could either be a setting in Aspire, or the softlimit settings in the DSP.
    Do you know what the softlimit settings are? And can you post the g-code to see where it exceeds them?
    Feb 2007
    4
    Hi, thanks for the help.
    Its a new machine so still trying to work it all out, works fine doing 3 axis work. Have not changed any settings on dsp since it arrived.
    Cant work out how to attach a file, so it is below, just a simple rounding toolpath to turn a square post 100mm round.
    ( ray1 )
    ( File created: Saturday June 30 2018 - 02:54 PM)
    ( for Mach2/3 from Vectric )
    ( Material Size)
    ( X= 314.159, Z= 50.000)
    ( Diameter = 100.000 mm)
    ( X Values are wrapped around the Y axis )
    ( X Values are output as A )
    (Toolpaths used in this file
    (Rounding Toolpath)
    (Tools used in this file: )
    (1 = Ball Nose {6 mm})
    N130 G00G21G17G90G40G49G80
    N140 G71G91.1
    N150 T1M06
    N160 G00G43Z76.721H1
    N170 S15000M03
    N180(Toolpath:- Rounding Toolpath)
    N190()
    N200 G94
    N210 Y0.000 A0.000 Z76.721 F6000.0
    N220 G00 A-90.000 Y0.000 Z76.711
    N230 G1 A-90.000 Y0.000 Z50.000 F900.0
    N240 G1 A-90.000 Y300.000 Z50.000 F6000.0
    N250 G1 A-84.000 Y300.000 Z50.000
    N260 G1 A-84.000 Y0.000 Z50.000
    N270 G1 A-78.000 Y0.000 Z50.000
    N280 G1 A-78.000 Y300.000 Z50.000
    N290 G1 A-72.000 Y300.000 Z50.000
    N300 G1 A-72.000 Y0.000 Z50.000
    N310 G1 A-66.000 Y0.000 Z50.000
    N320 G1 A-66.000 Y300.000 Z50.000
    N330 G1 A-60.000 Y300.000 Z50.000
    N340 G1 A-60.000 Y0.000 Z50.000
    N350 G1 A-54.000 Y0.000 Z50.000
    N360 G1 A-54.000 Y300.000 Z50.000
    N370 G1 A-48.000 Y300.000 Z50.000
    N380 G1 A-48.000 Y0.000 Z50.000
    N390 G1 A-42.000 Y0.000 Z50.000
    N400 G1 A-42.000 Y300.000 Z50.000
    N410 G1 A-36.000 Y300.000 Z50.000
    N420 G1 A-36.000 Y0.000 Z50.000
    N430 G1 A-30.000 Y0.000 Z50.000
    N440 G1 A-30.000 Y300.000 Z50.000
    N450 G1 A-24.000 Y300.000 Z50.000
    N460 G1 A-24.000 Y0.000 Z50.000
    N470 G1 A-18.000 Y0.000 Z50.000
    N480 G1 A-18.000 Y300.000 Z50.000
    N490 G1 A-12.000 Y300.000 Z50.000
    N500 G1 A-12.000 Y0.000 Z50.000
    N510 G1 A-6.000 Y0.000 Z50.000
    N520 G1 A-6.000 Y300.000 Z50.000
    N530 G1 A0.000 Y300.000 Z50.000
    N540 G1 A0.000 Y0.000 Z50.000
    N550 G00 A0.000 Y0.000 Z76.711
    N560 G00 A-180.000 Y0.000 Z76.711
    N570 G1 A-180.000 Y0.000 Z50.000 F900.0
    N580 G1 A-180.000 Y300.000 Z50.000 F6000.0
    N590 G1 A-174.000 Y300.000 Z50.000
    N600 G1 A-174.000 Y0.000 Z50.000
    N610 G1 A-168.000 Y0.000 Z50.000
    N620 G1 A-168.000 Y300.000 Z50.000
    N630 G1 A-162.000 Y300.000 Z50.000
    N640 G1 A-162.000 Y0.000 Z50.000
    N650 G1 A-156.000 Y0.000 Z50.000
    N660 G1 A-156.000 Y300.000 Z50.000
    N670 G1 A-150.000 Y300.000 Z50.000
    N680 G1 A-150.000 Y0.000 Z50.000
    N690 G1 A-144.000 Y0.000 Z50.000
    N700 G1 A-144.000 Y300.000 Z50.000
    N710 G1 A-138.000 Y300.000 Z50.000
    N720 G1 A-138.000 Y0.000 Z50.000
    N730 G1 A-132.000 Y0.000 Z50.000
    N740 G1 A-132.000 Y300.000 Z50.000
    N750 G1 A-126.000 Y300.000 Z50.000
    N760 G1 A-126.000 Y0.000 Z50.000
    N770 G1 A-120.000 Y0.000 Z50.000
    N780 G1 A-120.000 Y300.000 Z50.000
    N790 G1 A-114.000 Y300.000 Z50.000
    N800 G1 A-114.000 Y0.000 Z50.000
    N810 G1 A-108.000 Y0.000 Z50.000
    N820 G1 A-108.000 Y300.000 Z50.000
    N830 G1 A-102.000 Y300.000 Z50.000
    N840 G1 A-102.000 Y0.000 Z50.000
    N850 G1 A-96.000 Y0.000 Z50.000
    N860 G1 A-96.000 Y300.000 Z50.000
    N870 G1 A-90.000 Y300.000 Z50.000
    N880 G1 A-90.000 Y0.000 Z50.000
    N890 G00 A-90.000 Y0.000 Z76.711
    N900 G00 A-270.000 Y0.000 Z76.711
    N910 G1 A-270.000 Y0.000 Z50.000 F900.0
    N920 G1 A-270.000 Y300.000 Z50.000 F6000.0
    N930 G1 A-264.000 Y300.000 Z50.000
    N940 G1 A-264.000 Y0.000 Z50.000
    N950 G1 A-258.000 Y0.000 Z50.000
    N960 G1 A-258.000 Y300.000 Z50.000
    N970 G1 A-252.000 Y300.000 Z50.000
    N980 G1 A-252.000 Y0.000 Z50.000
    N990 G1 A-246.000 Y0.000 Z50.000
    N1000 G1 A-246.000 Y300.000 Z50.000
    N1010 G1 A-240.000 Y300.000 Z50.000
    N1020 G1 A-240.000 Y0.000 Z50.000
    N1030 G1 A-234.000 Y0.000 Z50.000
    N1040 G1 A-234.000 Y300.000 Z50.000
    N1050 G1 A-228.000 Y300.000 Z50.000
    N1060 G1 A-228.000 Y0.000 Z50.000
    N1070 G1 A-222.000 Y0.000 Z50.000
    N1080 G1 A-222.000 Y300.000 Z50.000
    N1090 G1 A-216.000 Y300.000 Z50.000
    N1100 G1 A-216.000 Y0.000 Z50.000
    N1110 G1 A-210.000 Y0.000 Z50.000
    N1120 G1 A-210.000 Y300.000 Z50.000
    N1130 G1 A-204.000 Y300.000 Z50.000
    N1140 G1 A-204.000 Y0.000 Z50.000
    N1150 G1 A-198.000 Y0.000 Z50.000
    N1160 G1 A-198.000 Y300.000 Z50.000
    N1170 G1 A-192.000 Y300.000 Z50.000
    N1180 G1 A-192.000 Y0.000 Z50.000
    N1190 G1 A-186.000 Y0.000 Z50.000
    N1200 G1 A-186.000 Y300.000 Z50.000
    N1210 G1 A-180.000 Y300.000 Z50.000
    N1220 G1 A-180.000 Y0.000 Z50.000
    N1230 G00 A-180.000 Y0.000 Z76.711
    N1240 G00 A-360.000 Y0.000 Z76.711
    N1250 G1 A-360.000 Y0.000 Z50.000 F900.0
    N1260 G1 A-360.000 Y300.000 Z50.000 F6000.0
    N1270 G1 A-354.000 Y300.000 Z50.000
    N1280 G1 A-354.000 Y0.000 Z50.000
    N1290 G1 A-348.000 Y0.000 Z50.000
    N1300 G1 A-348.000 Y300.000 Z50.000
    N1310 G1 A-342.000 Y300.000 Z50.000
    N1320 G1 A-342.000 Y0.000 Z50.000
    N1330 G1 A-336.000 Y0.000 Z50.000
    N1340 G1 A-336.000 Y300.000 Z50.000
    N1350 G1 A-330.000 Y300.000 Z50.000
    N1360 G1 A-330.000 Y0.000 Z50.000
    N1370 G1 A-324.000 Y0.000 Z50.000
    N1380 G1 A-324.000 Y300.000 Z50.000
    N1390 G1 A-318.000 Y300.000 Z50.000
    N1400 G1 A-318.000 Y0.000 Z50.000
    N1410 G1 A-312.000 Y0.000 Z50.000
    N1420 G1 A-312.000 Y300.000 Z50.000
    N1430 G1 A-306.000 Y300.000 Z50.000
    N1440 G1 A-306.000 Y0.000 Z50.000
    N1450 G1 A-300.000 Y0.000 Z50.000
    N1460 G1 A-300.000 Y300.000 Z50.000
    N1470 G1 A-294.000 Y300.000 Z50.000
    N1480 G1 A-294.000 Y0.000 Z50.000
    N1490 G1 A-288.000 Y0.000 Z50.000
    N1500 G1 A-288.000 Y300.000 Z50.000
    N1510 G1 A-282.000 Y300.000 Z50.000
    N1520 G1 A-282.000 Y0.000 Z50.000
    N1530 G1 A-276.000 Y0.000 Z50.000
    N1540 G1 A-276.000 Y300.000 Z50.000
    N1550 G1 A-270.000 Y300.000 Z50.000
    N1560 G1 A-270.000 Y0.000 Z50.000
    N1570 G00 A-270.000 Y0.000 Z76.711
    N1580 G00 Z76.721
    N1590 G00 Y0.000 A0.000
    N1600 M09
    N1610 M30
  1. K40 X axis problem using Corel Laser and WMF cutting mode
    By Die-Man in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 07-11-2017, 03:17 PM
  2. Vectric VCarve Pro - Embossing Dies - V-Carve toolpath problem
    By Kpt Steyn in forum Jewelry Design Software
    Last Post: 03-24-2017, 01:07 PM
  3. Z axis in Vectric V carve pro.
    By alanstclair in forum Uncategorised CAM Discussion
    Last Post: 07-09-2012, 02:30 AM
  4. Any Vectric program for 4th axis?
    By GTC in forum Vectric
    Last Post: 04-05-2012, 05:04 PM
  5. 4 axis rotational cutting problem
    By kilrabit in forum MadCAM
    Last Post: 11-30-2010, 02:26 AM
