586,121 active members*
3,613 visitors online*
Results 1 to 6 of 6
    Mar 2016
    20
    LinuxCNC + Mpg help please
    Hi I am retrofit denford orac to linuxcnc/mach3. I have got mach3 fully working but I cannot handle linuxcnc. I am trying to add mpg into but I have some strange issue with it.
    I have wrote the code and place it into custom.hal. Seems like mpg works but only one direction doesn't matter with way I am turning (If I am using arrows work great). I have windows xp with mach3 installed on another partition and the same mpg works great too. Can any one have a look in my code is there anything wrong with it
    My code:
    loadrt select8 count=1
    loadrt updown count=1
    addf select8.0 servo-thread
    addf updown.0 servo-thread
    net encA encoder.1.phase-A <= parport.1.pin-12-in
    net encB encoder.1.phase-B <= parport.1.pin-11-in
    net enc-counts encoder.1.counts => axis.0.jog-counts axis.1.jog-counts
    net jog-button updown.0.countup <= parport.0.pin-15-in
    net jog-choice updown.0.count => select8.0.sel
    net jogX axis.0.jog-enable <= select8.0.out0
    net jogY axis.1.jog-enable <= select8.0.out1
    setp encoder.1.counter-mode 1
    setp updown.0.max 1
    setp updown.0.min 0
    setp updown.0.wrap 1
    setp axis.0.jog-scale 0.1
    setp axis.1.jog-scale 0.1
    Feb 2008
    644
    Re: LinuxCNC + Mpg help please
    Quote Originally Posted by lolos View Post
    My code:
    setp updown.0.max 1
    setp updown.0.min 0
    You have the encoder mode set wrong:
    This should be
    setp encoder.1.counter-mode 0
    or better
    setp encoder.1.counter-mode false
    From the encoder component manual page:
    PINS
    encoder.N.counter-mode bit i/o
    Enables counter mode. When true, the counter counts each rising
    edge of the phase-A input, ignoring the value on phase-B. This
    is useful for counting the output of a single channel (non-quadrature)
    sensor. When false (the default), it counts in quadrature mode.
    Mar 2016
    20
    Great You are a star thanks - works!!!! I have to play with ilowpass now.
    I have got one more question
    - Can I use 2 different mpg's for X and Z
    cheers
    Feb 2008
    644
    cheers
    Sure, you would need to add another encoder instance (and 2 free input pins for the second MPG encoder)
    Since the jog keys still need the per axis selection but the MPGs do not, you would need to change the per axis
    jog enable logic to allow simultaneous X/Z jogging via the MPGs
    Mar 2016
    20
    If I go for it ...is that code correct then?
    net encA encoder.2.phase-A <= parport.1.pin-13-in
    net encB encoder.2.phase-B <= parport.1.pin-15-in
    net enc-counts encoder.2.counts => axis.1.jog-counts
    Mar 2016
    20
    doesn't work
  1. LinuxCNC 2.7.3 G0 Z0
    By GeeB in forum LinuxCNC (formerly EMC2)
    Last Post: 03-27-2016, 01:10 PM
  2. LinuxCNC 2.7.1
    By kstrauss in forum Tormach PathPilot™
    Last Post: 10-18-2015, 08:21 PM
  3. LinuxCNC?
    By MBViklund in forum Novakon
    Last Post: 01-29-2015, 06:33 AM
  4. Linuxcnc 2.5.2 won't run
    By cpeter in forum LinuxCNC (formerly EMC2)
    Last Post: 04-24-2014, 12:54 PM
  5. LinuxCNC right for me?
    By punisher454 in forum LinuxCNC (formerly EMC2)
    Last Post: 06-18-2012, 04:56 AM
