586,072 active members*
4,778 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > Haas CNC Mill 179 alarm question
    May 2018
    5
    Good day to you all.
    I have a question and would appreciate an answer as soon as possible.
    I have a 179 alarm (Transmission oil is low or low pressure condition in oil lines) on my company’s Haas Mill. I tried to call my Haas factory outlet, but I was too late in the day to catch them.
    I’m going to be checking to see what the causes might be, but in the event it is just low oil level, the Haas calls for Mobil DTE 25. However, I don’t have any on hand, only Mobil DTE 24.
    Do you know, or have any of you used DTE 24 oil in place of DTE 25 for the transmission oil on a Haas mill?
    Any help is greatly appreciated.
    Nov 2006
    490
    Re: Haas CNC Mill 179 alarm question
    I don't think it would cause any massive damage, just a different type of hydraulic fluid for lubricating the gears. Worst case is you could change the fluid later which would eliminate most of it from the system.
    I think it would be more important to avoid overfilling the transmission. I don't remember the exact fill amount off the top of my head, but you can find it in the maintenance manual.
    We change our transmission oil ever year just for preventative maintenance sake.
    Mar 2010
    1852
    There is a drain plug on the bottom side of the spindle. Four screws hold the inspection cover over it. You could check and see if any oil is in there by removing it and seeing if anything comes out, but I would just go to the top of the spindle and add oil. When the level is correct, it will overflow out of the small hole in that underside cover. In other words, you can't overfill it as the extra comes out (and that is how you are supposed to do it), just put a catch bucket under the spindle. When the transmission if filled, see if you still get the error. May also be a bad pump.
    I would get the correct oil, not hard to get at all. McMaster-Carr if nothing else.
    Mike
  1. haas mini mill alarm 160 and 119
    By cooljarz in forum Haas Mills
    Last Post: 01-17-2020, 08:28 PM
  2. Haas mill alarm 203
    By s00073055 in forum Haas Mills
    Last Post: 09-10-2015, 11:30 PM
  3. Haas Mill Stop No Alarm Spindle running
    By MachinistDan in forum Haas Mills
    Last Post: 10-06-2014, 12:58 PM
  4. No Interrupt alarm on 2001 Haas Mini Mill?
    By JasonR in forum Haas Mills
    Last Post: 08-01-2010, 07:06 AM
  5. Haas alarm 104 on a mini mill, bummer?
    By indian mark in forum Haas Mills
    Last Post: 06-19-2009, 01:32 PM
