586,075 active members*
3,729 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Need help in chamfering
Results 1 to 16 of 16
    Jun 2006
    7
    I have 316 material plate of 1/2 " inch thick and 18" inch long.. plate have 3 holes of 4" inch each ..i need to chamfer (45 degree) those holes for about 0.400 "inch in depth ..
    the problem is that the tool i am having has insert with cutting legth 0.275" inch ... i could think of doing it in 3D...
    but i appriciate any idea other than that...
    thank you
    Jan 2004
    3154
    Use 2.5D circular interpolation and 2 or 3 stepdowns.
    www.integratedmechanical.ca
    Jan 2006
    2985
    you could also use a 1" drill mill, although not insertable, would get the job done.
    http://www.use-enco.com/CGI/INSRIT?P...MPXNO=16720058
    Oct 2005
    251
    Do it in steps. Calculate the change in diameter relative to the vertical move. Program two, three or x passes to achieve the desired chamfer. Simple trig.
    Jul 2005
    12177
    Quote Originally Posted by ctate2000 View Post
    You hardly even need to use trig. With 45degrees if you come up 0.1" then you go out 0.1":
    Interpolate down to 0.4" with the tool tip at a radius of 2.1", then down to 0.3" with a radius of 2.2", then 0.2" with a radius of 2.3" and 0.1" with a radius of 2.4".
    You could do it in fewer cuts but the tool width in contact would be larger and could possibly lead to chattering.
    Jan 2007
    103
    i could make you a 1IN 4 fl. drill mill.
    you will still need to interpolate. but the chamfer will be done i 1 pass
    the 4 flutes should help elimate the chatter. i can make it carbide or hss
    i can even pvd coat the tool to extend tool life.
    Jan 2006
    4396
    Quote Originally Posted by Geof View Post
    Geof has a good idea with stepping down with a Mill Drill. You can get a 1/2 Diameter 4 Flute Carbide for around $47 dollars plus shipping and tax from Enco
    http://www.use-enco.com/CGI/INPDFF?P...PARTPG=INLMK32
    Cheers!!!!!!!!
    Toby D.
    "Imagination and Memory are but one thing, but for divers considerations have divers names"
    Schwarzwald
    www.refractotech.com
    Oct 2006
    51
    if you use an insertable cutter and you step up and over, make sure the 45° is right on the money. if not, you have mismatched lines in the chamfer.
    Jan 2006
    4396
    Quote Originally Posted by HIRAH View Post
    Well he could prevent this by Programming a .05 overlap in the Z axis
    Cheers!!!!!:cheers:
    Toby D.
    Schwarzwald
    Jul 2005
    12177
    Quote Originally Posted by tobyaxis View Post
    Cheers!!!!!:cheers:
    Sorry to disappoint you Mr Axis this would not work. If the cutting edge is not at 45 degrees then you have to use trig and calculate the stepover/depth ratio.
    Jan 2006
    4396
    Ooops!!!!! I was refering to a 45 Degree Mill Drill or Indexable Insert tool. Thanks for making it clear for others, LOL, I sometimes forget that I should include more information in replies to questions.
    As a Note I have used CAD/CAM to create 45 Degree Chamfers with Ball End Mills. This is a good trick when you run short of Tool Pockets in the Magizine on a CNC Mill. Hence you have to have a Ball End Mill already in the machine and it's diameter has to be smaller than the hole being Chamfered.
    Cheers!!!!!!!:cheers:
    Toby D.
    Schwarzwald
    Jul 2005
    12177
    ...As a Note I have used CAD/CAM to create 45 Degree Chamfers with Ball End Mills. This is a good trick when you run short of Tool Pockets in the Magizine on a CNC Mill. Hence you have to have a Ball End Mill already in the machine and it's diameter has to be smaller than the hole being Chamfered.
    How long does it take to interpolate a chamfer this way? I would guess you can tolerate a stepover of about 0.005" so for a 0.4" deep chamfer that means at least 112 times around the circle (0.4 * 1.4 / 0.005 = 112). For the 3" holes mentioned in this thread your tool would have to travel around the 3" circle 112 times for a total distance of 3 * 3.14 * 112 = 1055inches. This is going to take a long time...or am I missing something?
    Oct 2006
    51
    if the tool isn't at an almost perfect 45°, then changing the stepover won't help. the end result looks like shingles on a roof. 45s arent bad, but 30s suck. i usually program to the print, and add separate diameter offsets for each depth. total control without reprogramming.
    Feb 2007
    464
    Jun 2006
    7
    thanks to everybody for your help and comments
    i really like your ideas ... but this time i finished the job with 3D...
    i am sure next time i can try TRIGNOMETRY thing ..
    thanks guys
    Jan 2006
    4396
    You are correct. It takes a very long time Geof, but in a Crunch, you do what needs to be Done as you already know.
    "Imagination and memory are but one thing", "Which for diverse conciderations hath diverse names" Schwarzwald
    Not the Step Over, but the Step Down in the Z. You can use the same Program Coordinates XY and change the Cutter Comp for each step down. With a little math and a good machine you will be fine using a 45 degree Chamfering Tool.
    Quote Originally Posted by abcdef View Post
    thanks guys
    Glad you got what you needed and hopefully you learned the many ways to Skin This Cat of yours, LOL.
    Toby D.
    Schwarzwald
  1. Chamfering at diffrent heights?
    By turboboy in forum OneCNC
    Last Post: 11-30-2006, 01:29 AM
  2. need help with auto radius and chamfering
    By dry run in forum G-Code Programing
    Last Post: 01-30-2005, 09:52 AM
  3. chamfering
    By Mortek in forum Uncategorised MetalWorking Machines
    Last Post: 02-07-2004, 04:24 AM
