586,058 active members*
4,232 visitors online*
Page 2 of 2 12
Results 21 to 30 of 30
  1. #21
    Feb 2008
    280
    Re: M39 Spindle encoder getting crazy numbers
    Quote Originally Posted by forhire View Post
    Even after running the encoder a bunch I'm still not seeing any errors on the PID screen. I guess that means it's working?
    Meaning that if, for example, you start with the count near zero and run it with the drill at ca. 250RPM for one minute, then the count on the PID screen ends up in the vicinity of 2,000,000?
    If so, then the question should go to the software staff at Centroid. To the best of my knowledge, the status window actual-RPM display (with P78 = 1) has no multpliers except for varying spindle range (and that would only apply with bit 4 of P36 set).
  2. #22
    Dec 2005
    504
    Quote Originally Posted by cncsnw View Post
    Yes, but I haven't tried that test specifically. I'll zero it out and try it. It has been very consistent suggesting a multiplier or setting in software.
  3. #23
    Dec 2005
    504
    I ran the test this morning. 1.9M count after 1 minute. I opened a ticket with Centroid.
  4. #24
    Aug 2016
    16
    I'm thinking it may be signal voltage. This tech note lists the the high must be greater than 3.5V.
    http://www.centroidcnc.com/dealersup...ploads/280.pdf
    1. Confirm that you encoders meet Centroid signal specifications. Centroid requires
    quadrature, differential line driver encoders that meet the RS422/423 specifications. In
    addition, the “low” signal level must be < .5VDC and the “high” must be >= 3.5VDC.
    The spec sheet from Omron lists the Vo: 2.5 V min. and Vs: 0.5 V max. This matches the spec sheet for the TI RS422 differential driver chip used on this clone. I don't recall what the voltage was when we had it on the scope.
    I wonder what Centroid is thinking. A real RS422 receiver shouldn't care what the voltages are, only the difference between the lines. That is the whole point of using differential signals.
    I guess I need to find an encoder that meets Centroid specifications.
    The 3.5V and 0.5V thresholds are for the encoder connection detector circuit. The actual voltage thresholds may also vary based on the generation of your control card. If you are not getting "Bad Encoder Connection" messages, this is not a big problem. Other than the message, the levels only have to meet normal RS422 levels.
    The E6B2-CWZ1X is only rated to 100khz. This means the top speed will only be about 3000RPM. Not sure if you noticed this or if it will be an issue for your application, just pointing it out.
  5. #25
    Dec 2005
    504
    Quote Originally Posted by cen199 View Post
    Good catch on the frequency limit. I ordered a 100 PPR encoder a few days ago, it will keep me below the limit.
    Tech support had me re-apply the latest 2.72 update, thinking that there may be a corrupted file, but it still reads high even at low rpm.
    I'm not seeing the index asterisk pulse on the PID screen so I'm still leaning to there being a signal level issue. The encoder counts without errors even with the Z index removed. I'm stumped.
  6. #26
    Dec 2005
    504
    We put a buffer one each of the signals to bring them all above 3.5V. The Z index signal was around 3V and we felt it was below the typical 3.5V cmos threshold. With the buffer all signals are now measuring 4V AND the Z index asterisk is showing on the PID screen. It doesn't appear the index is used because the displayed speed it still high with or without it connected. At least now I can confirm all A, B, & Z signals are being seen.
    I believe we upgraded the CPU to 1000mHz about 4 years ago when we added memory and upgraded to 2.72. Is it possible the that CPU speed change resulted in a change? Because RPM is a function of time would the CPU change affect the kernel timer or ticks?
  7. #27
    Feb 2008
    280
    I believe that the software is looking at the DSP clock on the CPU7/CPU10 board for its time reference, and so is not dependent on the speed of the PC processor. Not that it would be anyway; there are plenty of reliable ways to get reasonably accurate times on the PC side which are independent of CPU speed.
    The DSP clock on the CPU7/CPU10 should update at 4kHz (the chip's interrupt rate). That counter is made visible to the PC software through a dual-port RAM (memory-mapped I/O). If it were not updating at 4kHz, you would have serious axis-control problems, because it is that 4kHz interrupt which runs the PID position-control loop.
    Also, if the clock were counting too fast, then the reported spindle speed would be low (fewer encoder counts seen per each interrupt). In order for the DSP clock count to cause the spindle speed to read high, it would have to count too slow.
    Did you do anything to change the clock crystal associated with the ADSP-2101 chip on your Centroid CPU board?
  8. #28
    Dec 2005
    504
    Nope. i'm grasping at straws by now. The machine has always worked well.
  9. #29
    Dec 2005
    504
    The latest from Centroid tech support is that the MSI MS-6368 motherboard I have in the PC does not support greater than v2.36 even though we upgraded to v2.61 in 2008 and v2.72 about 4 years ago. Not sure if it's a motherboard issue or motion control card issue. Support was kinda vague on the particulars and they wanted me to send the PC in. I can't really handle the downtime. Aside from the rpm display after putting on this spindle encoder we haven't had any issues. Zero! Now I need to pop the PC panel and see if it's really running the ISA motion controller or not.
    I booted it up on v2.61 yesterday and it exhibited the same issue. Now I really want to try v2.36.
  10. #30
    Dec 2005
    504
    Centroid tech support was able to duplicate the issue. They said the spindle display shouldn't affect my ability to rigid tap and sent a demo code to try it. They recommended setting parameter 78 to display programmed speed instead of encoder speed. Still trying to learn if upgrading the motherboard would correct the issue.
Page 2 of 2 12
  1. Motors go crazy when I turn the spindle On
    By DoctorBit in forum Chinese Machines
    Last Post: 06-15-2016, 09:25 PM
  2. Spindle going crazy
    By nzben in forum Cincinnati CNC
    Last Post: 07-08-2012, 11:13 AM
  3. Sherline spindle to 30k RPM -- am I crazy?
    By nicad in forum Uncategorised MetalWorking Machines
    Last Post: 11-17-2010, 09:57 PM
  4. Lathe Post giving crazy numbers
    By lynn mynatt in forum BobCad-Cam
    Last Post: 05-29-2009, 01:32 PM
