586,635 active members*
2,971 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > Huanyang Motor Overload
    Apr 2016
    22
    Hello, I have trouble with error EoAn in my Huanyang vfd. According to the error codes this should be due to Motor Overlad at normal operation speed.
    It have started to happen quite often even when i'm doing low load cuts. If I just turn the spindle on and let it spin without any material I dont get the error. Have anyone any experience or knowlede what to do with this?
    edit: Seems like it also stops randomly without any error. Could it be noise on the control signal to the VFD? Could that also give an overload error?
    15362
    Re: Huanyang Motor Overload
    Quote Originally Posted by PotatoMill View Post
    What motor or spindle are you using and how do you have your Parameters set
    Sounds like a Parameter or wiring problem
    Mactec54
    Apr 2016
    22
    I use a 2.2Kw water cooled Chinese spindle.
    I actually used your list for parameters last time I set the parameters.
    PD000=0 for Parameter unlock ( 1 ) for Parameter Lock
    PD001=0 (1 For Remote Control)
    PD002=0
    PD003=400
    PD004=400
    PD005=400
    PD007=20
    PD008=220
    PD011=120 (Minimum Setting 120) This can be set at 100 But 120 is a safer number to use with this VFD
    PD009=15
    PD010=8
    PD13= 08 is for Factory reset, Only use this to set VFD to Factory Default Settings
    PD014 Accel=12 ( Adjust to suit)
    PD015 Deccl=12 (Adjust to suit) ( PD15 is ignored IF PD26=1 Then the Spindle will Coast to a Stop)
    PD141=220 ( Motor Rated Voltage )
    PD142=9 ( Motor Max Amps) (Set for your motor Amp Rating 2.2Kw Spindle 9 amp Max)
    (Set for your motor Amp Rating 1.5Kw Spindle 7 amp Max)
    PD143=2 ( Motor Number of Poles)
    PD144=3000 (Max Motor RPM) =3,000= (24,000)
    The only difference is that I use remote controlled start and stopp PD001=1 but not remote controlled speed control PD002=0 due to inconsistent speed.
    Since I have messed around with the settings before it could be some other parameters I have set without remembering other places. I can try to do a factory reset and only set the parameters in the list and se if it changes anything.
    Edit:
    Just tried turning off the remote control for the start and stop signal for the VFD. Afterwards I manage to do a long run without any stops. Ill do some more testing and see if the problem re appears.
    15362
    PD002=0
    PD003=400
    PD004=400
    PD005=400
    PD007=20
    PD008=220
    PD009=15
    PD010=8
    Edit:
    Then check that the spindle Ground Pin 4 has continuity to the spindle body, Just remove the plug, most don't and this needs to be fixed if it is not connected, blow the water out before you remove the top if you have to
    Show some photos of your wiring this can help to see if there are any problems also
    If you where not using shielded cables for the speed control and on / off then this can cause problems like this also
    Inconsistent speed could be from wiring not being correct
    Mactec54
  1. Motor overload #31
    By naytep in forum Fadal
    Last Post: 05-05-2016, 12:24 PM
  2. motor overload
    By gamila in forum Fadal
    Last Post: 12-24-2013, 03:05 PM
  3. Hydraulic Motor Overload.
    By Temo in forum Cincinnati CNC
    Last Post: 10-18-2012, 05:49 AM
  4. 4525 motor overload
    By charliemisa in forum Fadal
    Last Post: 02-21-2011, 09:15 PM
  5. Spindle motor overload
    By Sprew in forum Fadal
    Last Post: 01-21-2010, 04:33 AM
