586,067 active members*
4,722 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Adventures in Converting my Precision Mathews Milling Machine to CNC
Page 1 of 3 123
Results 1 to 20 of 48
    Jun 2018
    36
    A couple of months back I purchased the Precision Mathews PM-25MV (see image links below). The goal was to convert it to CNC so I could do my own rapid prototyping. I looked around for conversion kits, but nobody had any in stock and it would be a while before anyone could make one. After a quick search on McMaster to estimate how much the aluminum stock would cost, I decided to save both time and money and make my own kit. How hard could it really be?
    I started by completely disassembling my PM-25MV and measuring everything with my vernier calipers (they were passed down to me from my dad and I've been too sentimental to buy digital calipers). After I put the machine back together I moved onto the next step, making a CAD model. Big mistake! Turns out not all my measurements matched up, including under the saddle (or was it my bad hand writing?). I had to completely disassemble the machine a second time to verify a few measurements.
    After I had designed my own kit using my CAD model, it was time to make chips. MANY hours later, all the parts were machined and everything was ready for the CNC conversion. I disassembled the machine for the third time and rebuilt it using my new parts. The X and Y axis conversion went smoothly. I only had the Z axis left to do... and one of my parts wouldn't fit! There was a mistake in my design! The only way to fix it was to completely disassemble the machine, rebuild the machine back to its manual configuration, and remake one of the parts for the Z axis conversion. At this point I could completely break down and rebuild a PM-25MV in my sleep, including tramming the head!
    After correcting my design flaw, I disassembled the machine for the 5th time, removed all the lead screws, and replaced them with my new ball screws and CNC conversion parts. This time everything worked perfectly.
    Here's the image link to the machined parts for the first conversion kit I made:
    Original Conversion Kit
    I was quite pleased with my conversion, especially considering all parts were made manually. However, I didn't like the way the stepper motors protruded out almost 8 inches. I also didn't like the way the couplers and bearings were exposed to chips and cutting fluids, especially if I were to upgrade to flood coolant in the future. I decided to go the extra mile and redesign my conversion kit in Fusion 360. This would allow for a much more compact design. At this point in the project I also finally caved in and bought digital calipers.
    After disassembling my machine for the 6th time and rebuilding it with the newer parts, I finally had the CNC conversion kit I wanted (and had been dreaming about). I had also put 200+ hours into the project and had spent more money than the cost of a ready-to-go, bolt-on conversion kit. What an adventure!
    So, if you're thinking about doing your own CNC conversion, I have some advice to share:
    1. Don't do it if you think you'll be saving time or money.
    2. When creating the CAD model, don't rebuild your machine until you've measured everything at least twice and drawn the entire model.
    3. Get digital calipers if you don't own them already. It's cool using the vernier calipers my dad used and handed down to me, but he got it in the days of valve radios, back when dinosaurs still roamed the earth. I'm starting to see why the world went digital.
    4. Don't be surprised if you start having dreams about rebuilding your machine and making conversion kits in your sleep.
    Here's image links to my current CNC conversion:
    PM-25MV with Conversion Kit
    X and Y Axis
    Machined Parts
    I'm also happy to answer any questions you might have about converting the PM-25MV to CNC. I also made a couple extra sets of parts while making my own kit if you would like a bolt-on ready kit.
    Now I need to decide what adventure I want next... spindle speed upgrade, flood coolant, or maybe power drawbar and ATC? Any suggestions?
    Happy machining!
    Dec 2013
    5717
    Re: Adventures in Converting my Precision Mathews Milling Machine to CNC
    Nice job! :cheers:
    I'm still using vernier calipers that I got back when the dinosaurs roamed the earth. I have digitals also, but I like my verniers. I do have to use my magnifier to read them now.
    Jim Dawson
    Sandy, Oregon, USA
    Looks awesome!
    Spindle motor and coolant were huge steps for my G0704 when I did them.
    Power draw bar is a nice luxury to have. ATC, for the type of work I do might be cool and potentially would save me some time, but it would be pretty minimal. Especially after balancing the amount of time it would take to create the ATC in the first place. That's a lot of manual tool changes.
    Jan 2017
    5
    It sure looks beautiful!
    I've just ordered my own PM-25MV, and I'm avidly searching the internet for any additional information about it.
    Have you any information on the amount of backlash you get in your axis? From my reading, ball screws aren't perfect.
    Right now, I'm totally strapped for cash, and there is no way I could go out and buy a CNC kit for my new mill.
    So I entertain myself with plans to 'make' all my own parts over the course of a few months.
    Just out of curiosity, can you make your CAD models available?
    Apr 2008
    61
    Search Franco CNC on YouTube. He has really good cad models of the PM25 linked in one of his videos.
    https://youtu.be/FR6Na9ZWmLs
    Sent from my SM-G892A using Tapatalk
    Jan 2017
    5
    Thanks fusion.
    Yes, I have seen Franco's videos. And have been playing with his free plans for the last few days.
    I think I see elements of Franco's designs (or at least some similarities) in CNCFusion's parts. But there are a few differences as well.
    It makes me wonder if CNCJoseph and Franco are the same individual, or if they have shared some aspects of their design with each other.
    In particular, the X and Y stepper mounts are visually similar to each other.
    Anyway, I await CNCJoseph's input into this matter.
    Jan 2018
    1516
    Same here, Thanks Fusion.
    I'm going to be buying a clone machine the next size up from the pm25.
    Looks almost identical apart from more depth for extra Y travel.
    Will have a look at those plans
    Apr 2007
    56
    Nice Job!!! I'm in the research part of my conversion. I know I have settled on the pm-25mv though. Did you go with mach 3,4, or acorn? Just custion on the spec side of your build also. Thanks
    Jan 2018
    1516
    Well.
    I've just put a deposit down at Amadeal on my machine (AMAT25LV-R8) to secure one, due in around 2-3 weeks. They go pretty quick so wanted to be sure. I've downloaded as many plans as poss and my lil' SiegX2 can make the bits.
    Ordered some couplings, oiling/greasing parts & about to start building a base/enclosure thing.
    Can't order screws yet until I know the exact sizes of the machine.
    Busy time coming. Can't wait
    I may have to look at the Z travel. I use a few direct collets as well as the chuck so may need to bring it closer to the table. Might have to figure out a new gas strut design. The one in the back may limit how low I can go.
    I'll machine the slot in preparation and leave it until it gets some funds back. Going to expand the Y hopefully another 15mm at least as well.
    So much for warranty
    Jun 2018
    36
    Ziptie007, thanks for the kind words. I actually went with the Centroid Acorn. I haven't had any issues with it. I also got their pendant which was a nice upgrade. As for other specks, I used 640 oz-in stepper motor on the Z axis and 570 oz-in stepper motors and the X and Y axis. I know people have had success with the 570 oz-in on the Z axis, but I liked the idea of having a little more torque on the Z.
    LBay, actually Franco and I are not one and the same. Thanks for the compliment though I developed my conversion kit before Franco released his video.
    I'm happy to answer any other questions anyone has on my conversion kit. It's been running great for six months now.
    Happy Machining.
    Jun 2018
    36
    Quote Originally Posted by CL_MotoTech View Post
    Looks awesome!
    CL_MotoTech,
    I have decided to take your advice and focus on the spindle motor next. Unfortunately I am having a hard time finding any information on upgrading the spindle motor on the PM-25MV. I started a new thread to this effect.
    How to Increase RPM on PM-25MV (or similar G0704)
    Since you have experience with the G0704 spindle motor upgrade, it would be very much appreciated if you (any anyone else with spindle motor upgrade experience) could chime in on that thread.
    Apr 2018
    9
    Quote Originally Posted by CNCJoseph View Post
    CL_MotoTech,
    I went through several option trying to control the stock motor with acorn or upgrade the spindle motor. The Chinese one from automationtech is garbage. Leeson makes a metric 1.5hp d80 face motor that is small enough to make work. Especially if you extend the head with a spacer. You will need a VFD too. I ended going with a small 3 phase motor from Groschop. The most powerful one they make is 1.1 hp. They have a controller and signal isolator to match too. The motor and controllers were about $500. They were really helpful with the purchase and will customize the shaft if you want. The one I got could not have the encoder mounted because it needs a fan. I was able to machine the fan a bit so I could mount my own encoder. I am now able to turn on, turn off,acorn can see the spindle speed and control the spindle speed through acorn. Max spindle speed is 6240 at 1:1 ratio using the stock pulleys(modified for shaft size) and belt . It is amazing that the machine now runs cooler. I can run at 6000 rpms for hours and the warmest spot on the machine is about 150 deg F. I did upgrade the spindle bearings to SFK bearings but did not switch to AC bearings.
    I also upgraded to a TTS power drawbar. I used the G0704.com project as a guide to make it. This is an expensive upgrade that took several attempts. The pneumatic cylinder is expensive and I had to buy 2 because I got some bad advice. If you want to make your own it may save some $ but I doubt it. I now have a working power drawbar TTS spindle. It is really nice. Effortless tool changes. Just be aware that Tormach only recommends 1/2” bits and smaller with tts. Increasing the hp may be counterproductive along with the TTS depending on your intentions.
    I can help more if you are interested. The motor is nice. I do wish I had gone with the Leeson just because of the higher hp. It is substantially larger though and would require the head spacer and not money. I do believe that the stock motor is controllable through acorn but would require more advanced electrical knowledge than I have. The trick is turning it on an off. Spindle speed is pretty easy with a signal isolator. There is very little info on the stock controller electronics so I scraped it and upgraded.
    My next project is to increase the y-axis travel. I am right in the middle of the head spacer project right now. One flaw of the PM is that only about 5” of the 6.6” of y axis travel is usable because the spindle isn’t centered over the travel. (I made the mistake of using a double ball nut so my travel is about 6.6.) I need to flip the ballnut and get a longer ballscrew. I haven’t determined if this will do the trick or not.
    Mar 2009
    27
    Quote Originally Posted by TCanndee View Post
    This is exactly what I was searching for. I've been converting a PM, using one of the available kits, and I'm finding it hard to believe the Y axis isn't centered below the spindle. I thought maybe it was the CNC parts that did it, but I dug out the original Y parts and they do the same thing.
    So what's the best solution for this? It would be nice if a second hole could be milled about 1.25" forward of the existing Y attachment, but I can't see if that's possible without taking it all back apart (again). You mentioned head spacer? Are you thinking of extending the head farther from the column to account for the alignment issue, or was that some other project you were working on?
    Thanks,
    Rusty
    Jun 2018
    36
    TCandee,
    Thanks so much for sharing your experience. It's really impressive to hear about all your upgrades.
    That was interesting what you said about wishing you had more hp. I've heard some people say that they think 1.0 hp should more than enough. It's good to get some perspective from someone who has actually done a spindle motor upgrade. This is the Leeson 1.5 hp motor I have been looking at for the past few weeks. I finally pulled the trigger and ordered it this morning.
    Leeson 1.5 hp Motor
    I have a conversion kit with single ball nuts monuted on my PM25. So far I haven't had any issue with travel. Some people think you've got to have double ball nuts, but I'm not sure it's worth the loss in travel on the Y axis. What little backlash you have (even with single ball nut) can be easily compensated for in the controller. Even the double ballnut still needs backlash compensation.
    Apr 2018
    9
    This looks like the motor I was looking at. I’ll respond to your other posts as soon as I get back to a computer. Doing this on my phone is frustrating at best.
    Jan 2018
    1516
    TCandee,
    What kind of backlash are you seeing?
    I'm yet to get my clone 25 out of the crate.
    Supposedly I've got 185mm travel on the Y and a 1kw BLDC motor (although the supplied manual says otherwise)
    I'm planning on cutting it out a bit to get close as poss to 200mm Y if it's possible.
    I think I'd be happy enough with 0.03mm (0.0012") lash in it and just use the comp when doing arcs or circles.
    Just finished getting the X2 to a reasonable state which ended up with 0.035mm lash but has a bit of lag for the first 0.02mm of movement. It'll do for making a kit for the new one.
    Need to reconfigure the garage so it'll fit and then crack on.
    Apr 2018
    9
    Quote Originally Posted by 13brv3 View Post
    Thanks,
    Rusty
    The best solution I have found is a head spacer between the head and the z axis slide with the dovetail. I went with 2.5". I am also working on expanding the y axis travel an inch or so to the front by using a longer ballscrew, enlarging the hole through the front of the base to allow the ball nut through and an extended stepper mount. Hoping to achieve 7.5-8.5". On the G0704's people are also using a spacer to move the column back. This is much more complicated on the PM because the column mount is on top and not the back. I think this will give me the most travel that is practical.
    I have no experience with Leeson motor you purchased. It was just an option when I was looking for an upgrade. The main reason for the motor upgrade for me was to increase the speed. Many have used belt ratio adapters to achieve this but that reduces the torque at the spindle. With my current Groschop 1.12hp motor I get 3120rpm at 1:1 and 60hz. I can run it up to 120hz and get 6240. It runs cooler now than it did with either the stock motor or the 1.5 BLDC that I got from Automation Tech. I can only credit this to how smoothly the motor runs. very quiet. If I would have decided to do the head spacer before the motor upgrade I probably would have gone with the leeson and a VFD. There just isn't enough room to do the Leeson and my PDB with the Fabco Air cylinder. I barely got this setup to fit.
    Apr 2018
    9
    Quote Originally Posted by dazp1976 View Post
    I am seeing about .002" in backlash. Y axis is .004 but I think I have a loose ballnut mount.
    I believe that you will get pretty close to the 200 mm you want on the y axis. My double ballnut was a bad idea. Working on a solution.
    I don't want to mention the brand online, but I was not impressed with the kit I used.
    Jun 2018
    36
    I'm surprised to hear you're getting .002" and .004" inch backlash on your CNC conversion since you mentioned your kit has double ballnuts! I have less than .002" on my X and Y axis. The kit I use has high quality single ballnuts. It's nice since you don't have to sacrifice additional travel on the Y axis. Here's a link to the kit I'm using:
    CNCElements PM-25MV CNC Conversion Kit
    Feb 2018
    79
    I've personally measured about .0015" of backlash on my X and Y and I believe I have an ArizonaVideo kit. (I bought it already converted so I can't remember 100% but it looks like his kit). Not sure whether or not it's double ballnut since I haven't taken it apart but I'd assume it's single.
    I have a Masso controller for my mill and for some hardware/software issue they currently have backlash comp disabled and it's eating away at me since I have a tendency to be a perfectionist with this sort of stuff lol.
Page 1 of 3 123
  1. Replies: 3
    Last Post: 04-12-2018, 08:20 PM
  2. Converting Milling Machine into CNC
    By duoblade in forum Hobby Discussion
    Last Post: 03-13-2018, 01:28 AM
  3. Tormach slant 15 or Precision Mathews 1330CNC
    By tankguykasota in forum Tormach Slant Lathe
    Last Post: 06-02-2017, 04:19 PM
  4. Replies: 1
    Last Post: 02-02-2017, 09:01 PM
  5. precision mathews and busy bee 11 x 27 lathe HELP
    By bluecollarcult in forum Uncategorised MetalWorking Machines
    Last Post: 12-10-2012, 08:50 PM
