586,058 active members*
4,744 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > please, i need help to configure a flat turning setup
    Jun 2015
    4154
    hello i have to deliver a hex27 on lb3000ex2
    please, i need help to configure this :
    ... left or right tools ? i guess left, so to avoid having chips on the part, but all chips to fall down
    ... smaller or bigger tool ? ph horn has from o40 to o100; i believe that a bigger tool will deliver the hex with less deviations, but cutting force will be greater
    ... 2 or 3 inserts ? there is a recomandation about 3 inserts being better for a hex ( attached )
    please, how to compute the shape deviations ?
    i don't have flat turning option ... should i consider buying hobbing ? what is the difference between hobbing and flat-turning ? from the controller perspective, not the tooling : for example, i believe that hobbing delivers any sync ratio, while flat turning is limited to 1:1, 1:2, 1:3 to 1:6; are there other differences ?
    kindly
    Aug 2011
    419
    Re: please, i need help to configure a flat turning setup
    Hi deadly
    Detailed information available in the special function manual.
    flat turning is very simple, the hobbing function has improved.
    "Imagination is more important than knowledge."
    Jun 2015
    4154
    hei kurmay / i need to check how the tool diameter influences the shape deviation, and i was trying to avoid understanding the math from the manual
    i wait the quote for both functions
    also i was said that i can "flat turn" without having the function installed, as long as i won't re-cut the same part + enough clearance + avoid some ignore codes
    kindly
    Jun 2015
    4154
    hello, a flat turn insert is 33-39 euro; please, is it possible to use a common type of insert ?
    also, is it possible to flat turn, by using a tool perpendicular to Z axis ? kindly
  1. Help with Okuma flat turning
    By rick kroeze in forum Okuma
    Last Post: 10-25-2017, 08:36 PM
  2. Replies: 0
    Last Post: 12-01-2015, 12:18 AM
  3. CNC Turning Setup-Operator
    By EnochHR in forum Employment Opportunity
    Last Post: 07-27-2012, 08:45 AM
  4. Considering buying flat turning option
    By ProToZyKo in forum Okuma
    Last Post: 04-14-2010, 02:33 PM
  5. Turning Tool Setup?
    By gbesch in forum Uncategorised CAM Discussion
    Last Post: 03-23-2010, 08:20 PM
