586,051 active members*
3,839 visitors online*
Results 1 to 1 of 1
    Jul 2018
    OMAX 2652 Issue. Help?
    A little bit of background information.
    The machine has done this for a little while however it has only progressed this last week and preventing us from producing any parts.
    The issue:
    When we turn the machine on at the pump it is fine however when we turn the switch on the main console there is a very quick and apparent popping noise at the back which can sometimes trigger the abrasive to flow.
    When it comes on however and we set the machine to do a low-pressure test to start it (after turning the charge pump on)The machine just completely cuts out and turns the console and the pump off.
    Has anyone got a vague idea with what the issue is or had a similar issue that they can advise us on?
    We have narrowed it down to an electrical fault which we will be seeing to in the near future, however a more clear idea would be better appreciated!
    Thank you in advance!
    Dan.
