586,069 active members*
3,565 visitors online*
    Jan 2013
    37
    MAZAK QT 20-HP CODE 202 NO HYDRAULIC PRESSURE
    Hello
    Has anyone every tried to remove the hydraulic motor/pump on the Mazak? Looks like it is built into the top cover of tank which doesn't seem right. Maybe a 1/4 turn to lock? Motor is turning with no pressure on gauges. Looking to remove to inspect for pump damage, pick up filter or motor to pump coupling.
    Thanks for your time.
    Jul 2010
    62
    Re: MAZAK QT 20-HP CODE 202 NO HYDRAULIC PRESSURE
    Had it been working ?.. Is it possible that motor is running wrong direction ?.
  1. Conquest almost working - no hydraulic pressure
    By rcpaisley in forum Hardinge Lathes
    Last Post: 09-06-2019, 06:27 AM
  2. Hydraulic pressure switch
    By jbranting in forum Cincinnati CNC
    Last Post: 05-02-2019, 12:54 PM
  3. Replies: 0
    Last Post: 10-21-2014, 02:49 AM
  4. VQC 15/40 NMI 201 Low Hydraulic pressure
    By Super Chicken in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 09-18-2012, 09:10 PM
  5. 1040 Low Hydraulic Pressure
    By pinguS in forum Fanuc
    Last Post: 06-18-2007, 02:53 PM
