586,052 active members*
4,210 visitors online*
IndustryArena Forum > Laser Engraving and Cutting Machines > Laser Hardware > 80W efr tube. How hard can I drive it?
    Jun 2018
    18
    Hi guys, I just got an 80w Chinese laser cutter with an efr tube.
    Research seems to suggest to add an ammeter and make sure the tube doesn't go beyond 30mA
    I have an ammeter but the installation process seems beyond me. Can anyone with the same tube or similar let me know what percentage corresponds to 30mA so I know not to exceed that
    Thanks guys
    Aug 2016
    75
    Re: 80W efr tube. How hard can I drive it?
    There are different models of 80w EFR tubes. For mine, you never want to exceed 28 mA and EFR states that 25 mA is the maximum if you want to get the maximum life out of your tube. Go to the Lasea EFR website for complete specs for your tube. You cannot rely on percentages from others because 1) you may not have the same model of EFR tube and 2) it is highly likely you will not have have the same brand and model number of power supply. Different power supplies result in different output for the same programmed % number in your Ruida controller.
    Keep the cooling water around 18C for best power consistency and long life.
    "80 Watt” 700mm x 500mm Ke Hui 7050 Laser (Similar to the Red Sail)
    Jun 2018
    18
    Quote Originally Posted by vrc321 View Post
    Thanks a lot! So turns out the power supply i have has a digital read out of the mA so no need to worry about installing the analogue Ammeter I purchased.
    Oh and unfortunately, the laser didn't come with a Ruida controller. It came with the cheapo M2 controller (the K40 one) so... yeah
    I have my water circulating around 20 degrees. Should I get it lower or is this fine?
    Ambient temperature in the workshop is around 27 to 32 degrees
    Quote Originally Posted by Montypaks View Post
    Water circulating around 20 C degrees should be OK
    Make sure Current is about 20- 25 mA
    https://www.automationtechnologiesin...ser-engraving/
    Jun 2018
    18
    Quote Originally Posted by automationtechinc View Post
    Thanks a lot! Much appreciated.
    So a general question. You said to run at 20 to 25ma. I've never actually run it that hard. It's about 5 to 10ma.
    So my question is is it better to run it at 25 mA which corresponds to 100% power and crank up the speed? How fast can I go?
    Is this better than running say at 5mA with slower movement say 200mm/s raster or 20mA vector
  1. Bad Hard Drive
    By judleroy in forum HURCO
    Last Post: 05-02-2022, 02:27 PM
  2. new hard drive with dolphin on the slave drive question
    By turbothis in forum Dolphin CAD/CAM
    Last Post: 06-13-2015, 08:53 PM
  3. DX32 hard drive (DOM Flash thumb drive) replacement procedures. WIP
    By Cellar Dweller in forum Bridgeport / Hardinge Mills
    Last Post: 01-06-2012, 05:26 AM
  4. HAAS VF3 hard drive or no hard drive
    By teal854t in forum Haas Mills
    Last Post: 08-18-2010, 03:27 PM
  5. Hard Drive
    By larry53 in forum Computers / Desktops / Networking
    Last Post: 01-04-2008, 10:19 PM
