586,036 active members*
3,617 visitors online*
Page 2 of 2 12
Results 21 to 40 of 40
  1. #21
    Dec 2017
    47
    Re: Help with L298N
    Thanks, what I don't know is where step, dir, and enable wire to the driver in the picture.
  2. #22
    Mar 2015
    410
    Re: Help with L298N
    Tb6600 <=> board
    Pul=step
    Dir=dir
    Ena=enable
  3. #23
    Dec 2017
    47
    Re: Help with L298N
    OK, here's my set-up. I have 3 drivers and this controller board, perhaps you could give me an idea how to wire it. I have a regulated 30V power supply, using NEMA 23 hi-torque motors. Really appreciate your help, thanks!
  4. #24
    Mar 2015
    410
    Re: Help with L298N
    Basically:
    - power the controller board like you dit before, using the 12V powersupply
    - connect the USB cable like you did before
    - power the TB6600 drivers using the 30V powersupply
    - connect the steppers to the TB6600 drivers
    - connect the steppers control signals step, dir, enable to the corresonding pins on the (removed) A4998 board, You have to remove this board!
    Tb6600 <=> 30V powersupply
    GND <=> GND
    VCC <=> 30V
    Tb6600 <=> Stepper
    A+ <=> to the same wire as previously connected to the board
    A- <=> to the same wire as previously connected to the board
    B+ <=> to the same wire as previously connected to the board
    B- <=> to the same wire as previously connected to the board
    Tb6600 <=> Controller board, A4988 driver board pin, remove A4988 board!
    Pul -(Pul) <=> step
    Pul+(Pul) <=> 5V
    Dir- (Dir) <=> dir
    Dir+ (Dir) <=> 5V
    Ena- (Ena) <=> enable
    Ena+ (Ena) <=> 5V
    I hope it is clear, if not explain what you do not understand.
  5. #25
    Mar 2007
    2083
    Re: Help with L298N
    with the A4988 stepper drivers removed
    you can connect the +5V , -step & - direction wires to the new stepper drivers like this :-
Name:	A4988 stepper driver  replacement.jpg
    you will need either to use solid wires to plug into the socket the A4988 stepper drivers has been removed from
    or
    solder flexible wires to the same type of male pins as used on the A4988 stepper driver
    https://www.pololu.com/product/965
    or
    https://www.pololu.com/product/1931
    John
  6. #26
    Dec 2017
    47
    Re: Help with L298N
    Thank you! I'll rewire everything today and let you know how it goes.
    - - - Updated - - -
    Thanks a million!
  7. #27
    Dec 2017
    47
    Re: Help with L298N
    https://www.cnczone.com/forums/attac...d=397390&stc=1Tried wiring it again, no luck, apparently I'm missing something. I removed the drivers from the controller, but can't figure out where the wires go to the new driver. Am attaching pic of my set-up.
    Could you possibly tell me where the step, direction, etc. go from looking at the pics, thanx!
  8. #28
    Nov 2012
    1267
    Re: Help with L298N
    Look at the drivers you have removed. They have pins clearly labeled as STEP, DIR, ENABLE and GND. Those pins go to PUL+, DIR+, ENA+ and GND on the new drivers. PUL-, DIR- and ENA- probably need to be connected to GND.
  9. #29
    Dec 2017
    47
    Re: Help with L298N
    Thanx!
  10. #30
    Mar 2007
    2083
    Re: Help with L298N
    going by post 17
    I thought you had this board
    Attachment 397398
    the one in post 27 has the arduino as a plug in module instead of built into the control board
Name:	Control and Driver.jpg
    the position of the step , direction +5V and gnd connections
    appears to be printed on the board but is not readable in your photo
    John
  11. #31
    Dec 2017
    47
    Re: Help with L298N
    Thanx!! I did have the other board, but swapped it on someone's advice, can't remember who. Where does the driver get the 5v power from, the controller, or do I need a separate 5v power supply?
  12. #32
    Mar 2015
    410
    Re: Help with L298N
    You must use the 5 volt from the controller. Locate the pin the way you used for the dir pin.
  13. #33
    Dec 2017
    47
    Re: Help with L298N
    No luck, just can't see what I am missing. Posting pics of my wiring, thanx for all your time and trouble!https://www.cnczone.com/forums/attac...d=397736&stc=1
  14. #34
    Mar 2015
    410
    Re: Help with L298N
    Quote Originally Posted by bjwx2 View Post
    Any 5 Volt pin will do. There are two pins on the arduino board ( i think it is a nano) on top of the controller board. And on the controller port there will be a pin labeled 5V.
    https://www.cnczone.com/forums/attac...d=397742&stc=1
    On the A4988 or DRV8825 board, it is pin VDD
  15. #35
    Dec 2017
    47
    Re: Help with L298N
    Can anyone explain what is connected to the 4 pins marked " INPUT"?https://www.cnczone.com/forums/attac...d=398016&stc=1
  16. #36
    Mar 2015
    410
    Re: Help with L298N
    These pins go directly to the L298N driver and are used to control the two motor outputs. In the data sheet of the L298N is explained how to use them.
  17. #37
    Dec 2017
    47
    Re: Help with L298N
    Still no luck with this arrangement, attached pic shows my wiringhttps://www.cnczone.com/forums/attac...d=398254&stc=1
  18. #38
    Mar 2015
    410
    Re: Help with L298N
    According to the picture, you connected Pul+, DIR+, ENA+ to the ground (green wire). Pul+, DIR+, ENA+ should be connected to the +5V.
  19. #39
    Mar 2007
    2083
    Re: Help with L298N
    first ,
    for your initial tests you can disconnect the enable wiring to your stepper driver
    without details of how the arduino based control board or the control software works
    I can not be sure if your controller is set up for
    active high or active low outputs to control the stepper drivers step or direction inputs or if its easy to change in software
    If the controller outputs are wired so the control GND is connected to the pulse & direction negative terminals
    and the control pulse & direction positive outputs go to there respective stepper driver + pulse & +direction terminals
    you could try it with the controller outputs are wired so the control +5V is connected to the pulse & direction positive terminals
    and the control pulse & direction negative outputs go to there respective stepper driver - pulse & - direction terminals
    like the diagram in post 30
Name:	active high or active low.jpg
    John
  20. #40
    Dec 2017
    47
    Re: Help with L298N
    Thanx! will try it today.
Page 2 of 2 12
  1. L298N Wiring?
    By bjwx2 in forum Questions or Problems
    Last Post: 07-07-2018, 10:17 PM
  2. L297 - L298n
    By reuven81 in forum Open Source Controller Boards
    Last Post: 07-17-2015, 08:08 PM
  3. Homemade BoB and Drivers (L297/L298N)
    By mk169474 in forum CNC Machine Related Electronics
    Last Post: 01-24-2013, 11:45 PM
  4. pluto-p l298n connection
    By AvioP in forum LinuxCNC (formerly EMC2)
    Last Post: 09-10-2012, 09:49 AM
  5. Parallel L298N driver circuit help
    By Sidco7 in forum Stepper Motors / Drives
    Last Post: 03-01-2011, 04:56 AM
