587,067 active members*
3,397 visitors online*
Results 1 to 7 of 7
    Oct 2008
    2100
    CONTINUOUS - Table Load - 1100
    I saw the spec where it says upto 500 lbs table load for the 1100, but I am wondering who has the highest continuous load on their table. I've been playing with various ideas for fixture plates, and I have some MIC6. Enough to make two full work envelope specialty tooling plates. I've been struggling with how I want to cut them down and prep them when it occurred to me I have two 8 inch lock down mill vises on a shelf I haven't used since I tore down my old RF45 for salvage and future projects. With just minimal planning I could mount them on the table of the 1100 to easily take advantage 100% (+) of the machine's work envelope. With outboard jaw mounting they have a grip range of about 16 inches, and of course 8 inches with jaws normally mounted. Once I mount them I won't want to take them off. They weigh about 100 lbs each. (96 comes to mind) Now I can lift a lot more than that, but reaching into an enclosure with arms extended to place them on the table about maxes me out. I won't want to do that very often. Hence why they will likely stay there if placed. That means a permanent extra 200 lbs on the table. Sure, the spec says 500 lb work piece, but I don't think it means 500 lbs all the time for years.
    So who has the heaviest permanent load on their table?
    How many years have you run it that way?
    P.S. 8 inch vises do not compare to 6 inch vises. I haven't weighed the 6 inch lock down vises I have on the table of my Hurco KMB1, but they feel like a feather compared to those 8s. Yes I considered using the 8s on the Hurco, but I'd have to cut holes in my home made table top enclosure just to spin the screws. LOL.
    Bob La Londe
    http://www.YumaBassMan.com
    Oct 2008
    2100
    Re: CONTINUOUS - Table Load - 1100
    I got to laying out the 8" on the table its just not going to work. I even looked at cutting the rear apron off the vise, but no go. It's just to darn big. I'd actually get less useable working envelope if I mounted it. I guess I'll be going with those two 6 inch vises off the Hurco after all. Nice thing about the Hurco is I can push the head in or out or even swivel it to cover every inch of the table, so while the 8 inch will be tight in the enclosure I can machine anything it can clamp. I think I can cover the hole for the handle with the skirt that covers the slides the doors ride on.
    Bob La Londe
    Jul 2007
    1602
    As an alternative approach, have you looked into the Pierson pallet systems? https://piersonworkholding.com/ The initial outlay is higher than the vises for sure but it is basically plug and play.
    bob
    Oct 2008
    2100
    Quote Originally Posted by rowbare View Post
    bob
    I have looked at it, nd its nice, but as you said it just a little more than a couple vises I already have. Actually, I have several pieces of MIC 6 for a pallet setup I am building, but I want to make it on a machine I am currently working on.
    Bob La Londe
    Jun 2011
    692
    The Kurt DX6 opens to 9" as do many of its clones (The Shars 690V is only 8.9") Still quite a bit more pricey than something already owned.
    Oct 2008
    2100
    Well MY six inch vises don't open much past six inches. THANKS A LOT FOR GETTING MY HOPES UP GUYS. (Just kidding I already knew they didn't.) I got them cleaned up and oiled and setting on the table. They don't quite line up using the keys to make the optiomum use of the work envelope, but then I realized they really don't have to. I can always move the jaw plates to the outboard sides of the jaws and throw a piece of tooling plate on them.
    By the way, I never knew other vises opened further than their claimed size. I guess that's what I get for buying lower price import vises. My 4 inch have jaws a smidgeon less than 4 inches wide and open to a little over 4 inch etc.
    I can't find my hard jaws for the second 6 inch lockdown vise though. Its had soft jaws for years, but I'd really like to find the hard jaws for now. I guess I may have to make a set. It would be a good job for a surface grinder if I had one.
    Bob La Londe
    Jun 2011
    692
    If you don't have a surface grinder, might you be better off buying a set? Unless they're weird screw spacing.
  1. Continuous Load Acramatic 950
    By byates2 in forum Controller & Computer Solutions
    Last Post: 01-20-2016, 11:28 PM
  2. RF45 max table load
    By sarel.wagner in forum Benchtop Machines
    Last Post: 08-04-2013, 12:20 PM
  3. Haas Rotary Table on an 1100?
    By HLF Ordnance in forum Tormach Personal CNC Mill
    Last Post: 04-10-2012, 06:38 AM
  4. 1100 usable table range
    By FannBlade in forum Tormach Personal CNC Mill
    Last Post: 04-02-2012, 03:46 AM
  5. Best Table Setup to Load Materials
    By schoobie in forum Torchmate
    Last Post: 06-09-2008, 04:12 AM
