586,061 active members*
4,308 visitors online*
IndustryArena Forum > CAM Software > MadCAM > Possible Bug —Version 6
    Jun 2012
    15
    I am using Madcam 5Extra,Version 6.0.2018.702. When creating a simple 2D profile, I select the curve to profile and the cutter outline and “direction of cut” arrow appear as normal. However, the profile curve generated is always on the opposite side from that selected. i.e., if I select an outside profile, MadCAM generates a cut on the inside.This error can be easily corrected by selecting the correct radio button in the pop-up window. So, there is a simple workaround.
    Just curious if anyone else has seen this behavior.
    Jerry
    Nov 2013
    36
    Re: Possible Bug —Version 6
    +1
    Sent from my Pixel 3 using Tapatalk
  1. Licenced Mach3 Version R3.043.022 and ESS changes to demo version
    By marcberv in forum Mach Software (ArtSoft software)
    Last Post: 01-22-2017, 02:49 PM
  2. Replies: 0
    Last Post: 12-28-2015, 10:15 PM
  3. Replies: 5
    Last Post: 06-26-2014, 12:02 PM
  4. powermax 45 machine version vs hand version
    By landmark in forum Hypertherm Plasma
    Last Post: 02-14-2010, 11:13 PM
  5. Replies: 2
    Last Post: 12-12-2006, 12:12 AM
