586,430 active members*
4,043 visitors online*
IndustryArena Forum > MetalWorking Machines > HURCO > Hurco bmc 40/20 ultimax 3 control boot issues?
    Oct 2009
    4
    Hello all,
    Hopefully someone has run across this problem! I power up the machine has no issues runs through the normal boot process until we get to where I should be powering the control up. Sometimes it will show a bunch of errors like heat sink,motor over temp, sometimes it will say all that then it will go away and say way lube low (it’s full?) or say low air pressure (has good air?) so not sure where to start. My guess is it is in the drive? It has Siemens simodrive 611.Anyone ever had this problem? Thanks in advance!!!
    Dec 2013
    5717
    Re: Hurco bmc 40/20 ultimax 3 control boot issues?
    Bad connection on the sensor common maybe? 24 volt power supply getting a bit weak, slow to come up to voltage?
    Jim Dawson
    Sandy, Oregon, USA
    Oct 2009
    4
    That is my other guess is power supply. We had a guy that worked on hurco’s at the last place I worked every time something was wrong seemed like he changed the power supply that would seem to be the cheaper route to start with. We took the I/r module out and tested what we could but we are limited on knowledge lol
    May 2017
    58
    [QUOTE=hack&wack;2197232]
    I had a very similar problem that was occuring on a hawk 5m with max 3. Here is what I did and iether the combination or the last few steps fixed my issue. I pulled and cleaned contacts on all boards and seating conectors. Cleaned all plugs. Then relays. It still would throw lube error now and then so I next swapped out RAM and cleaned conector to the hard drive. Ensure a good ground to all components.
  1. hurco control unit ultimax question
    By allenp in forum HURCO
    Last Post: 02-04-2017, 05:34 AM
  2. Hurco MD1 Ultimax 2 control lockup
    By rallyslag in forum HURCO
    Last Post: 10-09-2010, 05:00 PM
  3. Replies: 0
    Last Post: 04-19-2010, 07:45 PM
  4. Replies: 0
    Last Post: 11-12-2009, 03:25 PM
  5. Hurco BMC20 with Ultimax 2 control
    By kwmkoester in forum HURCO
    Last Post: 04-30-2009, 11:52 PM
