586,042 active members*
3,807 visitors online*
Results 1 to 9 of 9
    Sep 2013
    15
    Engraving Numbers
    Any help/suggestions on how to program number engraving?
    Im guessing it will be a manual program.
    Would be interested to know if numbers can be programmed using an endmill tool suitable.
    Numbers in question would be:
    • 0
    • 1
    • 2
    • 3
    Thanks in advance.
    Dec 2013
    5717
    Re: Engraving Numbers
    Create the text you want in any CAD or most CAM programs and just post process the text as normal G code. Most CAD or CAM programs have a text function that will generate any printable character. You could code it by hand also, but it's easier in software. You can use any suitable end mill or engraving bit depending on the size of the text.
    Jim Dawson
    Sandy, Oregon, USA
    Sep 2013
    15
    Hi Jim.
    Thanks for your quick reply.
    Unfortunately I do not have any CAD or CAM software.
    I will have to try and find something to do this.
    Thank you for your advice, much appreciated.
    Dec 2013
    5717
    How do you normally program your machines? You could draw the numbers on graph paper and manually generate the G code from that.
    Jim Dawson
    Sandy, Oregon, USA
    Apr 2016
    74
    what kind of machine are you using?, i can code the numbers for you if its just the g code you want?
    Apr 2017
    17
    End mill to use, depends on the size of the lettering.
    I use 1/16-1/8- 3/16-1/4 inch down cut end mills.
    mark-s
    Apr 2016
    74
    i like to use a harvey engraving tool
    Sep 2013
    15
    Hi folks....
    Programming is done in front of the machine.
    Mazatrol units or Manual units.
    CAD or CAM is never used.
    We are Metric parameters.
    Machine control is - Mazatrol Fusion 640M
    Any ideas how i can program the following numbers using metric dimensions:-
    Thanks in advance.
    Dec 2013
    5717
    Quote Originally Posted by D.E.L View Post
    Hi folks....
    Thanks in advance.
    You could draw the numbers on graph paper and manually generate the G code from that. It's possible to generate the numbers with only G1 moves.
    Jim Dawson
    Sandy, Oregon, USA
  1. Tormach Engraving - Conversational Sequential Serial Numbers
    By keen in forum Tormach Personal CNC Mill
    Last Post: 07-13-2017, 09:29 PM
  2. Drawing Numbers and Part Numbers
    By petesurrey in forum Uncategorised CAD Discussion
    Last Post: 08-20-2013, 10:12 AM
  3. Advice on Engraving numbers!
    By woodenink in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 06-12-2012, 01:11 PM
  4. engraving serial numbers
    By mls in forum Haas Mills
    Last Post: 09-18-2009, 02:22 AM
  5. Engraving Serial Numbers
    By drk in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 07-01-2007, 03:26 PM
