586,117 active members*
3,394 visitors online*
    100w Laser - how to get darker marks vs cutting
    Just started using a chinese 100w laser. I Have tried varying speed (100mm/s - 500mm/s) and power settings (10-90%) in rdworks using scan mode to raster some block text on a bamboo cutting board but have mainly been getting variations on cut depth rather than dark surface markings. I have also tried running some tests with a second pass (2x passes at same speed/power, should I be doing separate settings for each pass?) I have played around with lowering the table (to put laser out of focus) between passes but am not getting the results I am looking for. (dark marking, shallow /no cutting)
    Feb 2017
    5
    Re: 100w Laser - how to get darker marks vs cutting
    Try changing air pressure/volume from nozzle
  1. 50W Laser for paper cutting (how to avoid burning marks)
    By dude17 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 10-15-2019, 09:54 AM
  2. 100w laser cutting intermittently!!
    By Rhys_Mack in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 07-12-2018, 04:54 PM
  3. 100W laser engraving/cutting machine
    By lasertube in forum Commercial Laser
    Last Post: 06-11-2014, 06:30 PM
  4. New power of 100w fo CO2 laser engraving and cutting machine
    By vivinar in forum News Announcements
    Last Post: 10-21-2010, 02:09 AM
