586,700 active members*
3,065 visitors online*
Results 1 to 11 of 11
    Jul 2018
    14
    how to stop arcs from being interpolated
    Hello,
    I draw a circle, extrude, then generate a 2.5D operation "face mill" . The type is spiral. It should be producing gcode with 02/3 arcs. What's wrong here? The program is like 2500 lines.
    -Point interpolation is unchecked.
    -Approximate arc by line is unchecked.
    -Geometry is not silhouette
    -It is not a spline since it is just a circle created in solidworks.
    postprocessor is aweaFANUC
    In visi, the postprocessor does not interpolate, producing the same path of about 50 lines or less. Here it is 2500 and producing poor surface.
    Jan 2012
    36
    Re: how to stop arcs from being interpolated
    Hi cryptopsy,
    Unfortunately, there is no gcode command for a spiral. To be a true spiral, the arc (G2/G3) would not work because the spiral is actually a spline that is continuing to change as it gets bigger or smaller. Thus producing a point-to-point gcode.
    Highest Regards,
    Darrin - SolidCAM
    Jul 2018
    14
    Quote Originally Posted by Mikay19 View Post
    Hi cryptopsy,
    Highest Regards,
    Darrin - SolidCAM
    What spiral type should i use to replace the spiral with g2/3 moves? There must be some type that permits this, since i generated it in visi.
    What if i want to do a helical path, would it interpolate arcs? Like in this exact example :
    https://www.youtube.com/watch?v=rg5ucsg-W
    Nov 2012
    1267
    Edit: What kind of spirals are we talking about? A flat one ( R=var, Z=const)? Or a downward spiral (R=const, Z=var)?
    Jan 2012
    36
    I am assuming that visi did an arc fit during the creation of the spiral. Which means it is not really a spiral but a series of larger/smaller arcs that are connected. I don't see a way to create a true spiral using arcs.
    Regards,
    Darrin - SolidCAM
    Jul 2018
    14
    It is a spiral for a facing operation, so it is const Z and it doesn't have to be a true spiral.
    Jun 2010
    4256
    A true spiral has a constantly changing radius of curvature.Neither CAM programs nor g-code can handle that.
    However, one can do a very good approximation by doing a number of 180 degree segments at decreasing radii.
    Cheers
    Roger
    15362
    Quote Originally Posted by RCaffin View Post
    Cheers
    Roger
    Give me any possible curvature or spline you can come up with and I'm sure I can make the G-code for it in my cam program
    Here is a Spiral took me all of 2 minute's start to finish, of course it is not a true spiral, but anything is possible with a good cam program, the cam software I use has had this operation for about 15 years may be longer has many more useful operations like this
    Mactec54
    Jan 2012
    36
    cryptopsy,
    RCaffin is correct, you can draw the path in pretty simply if you really want a spiral like path without so many lines.
    Darrin - SolidCAM
    Jul 2018
    14
    Cheers
    Roger
    Visi generates this automatically. I should not have to draw my own spirals, because if i want to change the width of cut , or i change the tools, i have to redraw the spiral.
    Jun 2010
    4256
    I use a parametric program for spirals. Take radius R of spiral area, divide by 0.8*D, where D is the tool diameter, and you have the number of full loops needed. Both R & D are editable parameters. The 0.8 allows for path overlap. It's just maths, which g-code is well able to handle.
    Cheers
    Roger
  1. interpolated holes slightly smaller at bottom?
    By maker4444 in forum MetalWork Discussion
    Last Post: 09-02-2016, 02:15 AM
  2. heidenhain interpolated radius in X Y & Z
    By Smudger2 in forum G-Code Programing
    Last Post: 03-21-2014, 11:23 PM
  3. Interpolated circular pocket position???
    By mniadna in forum Haas Mills
    Last Post: 12-07-2010, 12:32 AM
  4. Incremental arcs and Break arcs into lines
    By forhire in forum NCPlot G-Code editor / backplotter
    Last Post: 09-16-2010, 04:55 PM
  5. Interpolated vs. dogleg rapids.
    By ckirchen in forum Haas Mills
    Last Post: 05-30-2009, 06:43 PM
