586,068 active members*
3,739 visitors online*
Results 1 to 9 of 9
    Jul 2005
    43
    Finishing questions
    Any tips on what I can do for a better finish. Trying to do a scallop and it cuts great one way but when it turns around it gets all these little hairs on it.
    Sent from my SM-G955U using Tapatalk
    Mar 2011
    480
    Re: Finishing questions
    Could be from the coventional cutting direction or thats a flat part where its using the tip of the cutter (assuming ball mill), but i can't really see the slope of the part. Try cutting only in the climb direction.
    Jul 2005
    43
    Yes it is with a ball mill on a slight slope. Ended up just doing a parallel instead but would like to figure out the scallop. I tried one way cutting which fusion says is climb cut only but it seemed to me to cut both ways still but left funky linking moves in the pattern
    Feb 2006
    7063
    Were you using coolant, or lubricant? Both can help a lot with that. But it's probably not realistic to expect it to come out perfect. You will almost certainly have to do a little clean up with some steel wool, a Scotchbrite pad, or some polish, no matter what you do.
    Regards,
    Ray L.
    Nov 2012
    591
    To avoid the hairs, try feeding faster, or spinning slower.
    Or cut with a face mill and then scrape scallops with a shaper :-)
    Mar 2009
    1863
    What is your coolant delivery method? Are you using spray or flood coolant? If you’re using a Fog Buster, I’d day that’s your problem because the Fog Buster doesn’t have enough air pressure to blow chips away.
    I would only use flood coolant for that application. I have a 2 nozzle Fog Buster and I only use it for profiling.
    You can buy GOOD PARTS or you can buy CHEAP PARTS, but you can't buy GOOD CHEAP PARTS.
    Jul 2005
    43
    I'm using XTREME CUT 250C by flood at 7% concentration. I have an upgraded pump, 5/8in lines and 3 nozzles. I'll try again playing with the feeds. See what that does.
    Mar 2011
    480
    Quote Originally Posted by dbunyip View Post
    Looks pretty flat, so probably using the center of the cutter where SFM is really low "dragging" the cutter. One way to increase SFM is to use a bull nose EM if the geometry will allow, or fixture the part at an angle so your not using the tip of the tool.
    Oct 2016
    128
    I see that when I get impatient and turn off the coolant for a second to take a look lol. But with that being said I bet it’s a lack of lube/chip recutting
  1. Replies: 1
    Last Post: 02-29-2016, 01:26 AM
  2. Brass vs Aluminium Vs Steel, questions, questions and questions...
    By alexccmeister in forum Uncategorised MetalWorking Machines
    Last Post: 08-15-2011, 06:40 PM
  3. Cut 3D Finishing
    By hstinnett in forum Vectric
    Last Post: 06-20-2008, 03:41 PM
  4. Finishing
    By jrobson in forum Surfcam
    Last Post: 03-06-2008, 10:59 AM
