586,077 active members*
3,638 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > Chinese Machines > woodpecker 3018 problems with X and Y axis and stepper motors
Results 1 to 1 of 1
    Hi! I recently bought a CNC 3018 that comes with a woodpecker board. After putting it together I managed to carve small designs (2cm), but recently I decided to make bigger things and I found a problem. If the stepper motor needs to move more than 25.00 steps (according to GRBLcontrol) it will stop and make a buzzing sound for a couple of seconds, not finishing its path and making the designs to look weird.
    I thought at first this could be a problem related to the stepper motors, but after playing a bit with the woodpecker board I found that all motors work fine when using the Z axis.
    Is there anything I can do to make it work?
  1. Woodpecker CNC 3018 issue - all axes locked
    By UT-Matt in forum Chinese Machines
    Last Post: 07-28-2019, 04:56 AM
  2. NOOB NEEDS HELP HAVE A CNC 3018 WITH A "WOODPECKER CNC GRBL 0.9 BOARD) NEED TO UP RPM
    By bruce1129 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 07-11-2018, 04:09 AM
  3. Two stepper motors for one axis.
    By hand1 in forum CNC Machine Related Electronics
    Last Post: 12-17-2014, 01:25 PM
  4. Using two stepper motors for one axis
    By gavinpoyner in forum Maintenance DIY Discussion
    Last Post: 05-06-2012, 02:32 PM
