586,111 active members*
3,225 visitors online*
Thread: Printing
Results 1 to 9 of 9
    Jan 2004
    190
    Printing
    Just finished my first cad drawing ever but can't get anything but a blank page to print any help out there thanks Kenneth
    thanks Kenneth
    www.lambertsrc.com
    Oct 2003
    927
    do you have the latest v19 upgrade? if not it is supposed to "fix" the printing problem...
    http://www.bobcadsupport.com/
    Jan 2004
    190
    i downloaded fix # 3
    thanks Kenneth
    www.lambertsrc.com
    Apr 2003
    372
    kenlambert
    It is true the problem has been fixed, try going to your bobcad shortcut under the start_programs menu and run a live update, this will fix the printing issue as well as a few others.
    Let us all know how you went.
    "A Helicopter Hovers Above The Ground, Kind Of Like A Brick Doesn't"
    Greetings From Down Under
    Dave Drain
    Akela Australia Pty. Ltd.
    Jan 2004
    190
    it says no updates were found
    thanks Kenneth
    www.lambertsrc.com
    Apr 2003
    372
    Ok kenlambert,
    I will look into it for you, give me 24hrs
    Cheers
    Dave Drain
    Jan 2004
    190
    ok thanks
    thanks Kenneth
    www.lambertsrc.com
    Jan 2004
    190
    Kookaburra
    it worked that time around thanks for the help Kenneth
    thanks Kenneth
    www.lambertsrc.com
    Apr 2003
    372
    great to here kenlambert.
    The only thing I could think of was if you have an entity selected it will only print that entity and if the particular entity is tiny it may pass off as a piece of dust on your page, it is always a good idea to get into the habbit of deselecting all of your geometry before printing.
    Enjoy
    Dave Drain
  1. Ricoh RW470 printing problems
    By cncadmin in forum Printing, Scanners, Vinyl cutting and Plotters
    Last Post: 03-15-2005, 06:00 AM
  2. pcboards and screen printing
    By lurch in forum CNC Machine Related Electronics
    Last Post: 10-17-2004, 07:40 AM
  3. Printing on hard surface tile?
    By jeffterm in forum Printing, Scanners, Vinyl cutting and Plotters
    Last Post: 10-01-2004, 11:32 PM
  4. V19 printing?
    By inthedark in forum BobCad-Cam
    Last Post: 02-28-2004, 09:46 PM
  5. Printing with TurboCAD
    By handersen in forum Uncategorised CAM Discussion
    Last Post: 06-17-2003, 10:17 PM
