586,619 active members*
2,424 visitors online*
IndustryArena Forum > MetalWorking Machines > Bridgeport Machines > Bridgeport / Hardinge Mills > What kind of tap holders do I need for a Torq - Cut 22
    May 2009
    107
    Anyone know for sure?
    Also I was wondering if the machine has the power to tap 3/4"-10 in 3/4" A 36 plate.
    Nov 2004
    164
    Re: What kind of tap holders do I need for a Torq - Cut 22
    Honestly I just use an ER collet and holder on #8 to 5/8 inch threads. Bigger than that I generally use a thread mill from LakeShore Carbide. I haven't had the best luck with smaller ones due to breakage and never had a job large enough volume to be worth the risk or effort to develop.
    Jun 2011
    152
    At that size I would also threadmill them. I do a lot of rigid tapping in collet and drill chucks for 10-32. I have found roll/form taps work well. It also depends on if you have a gear box or not. there were 3 spindles available, a direct drive, a high speed, and a high torque.
    I also use Lakeshore carbide stuff.
    Richard
    May 2009
    107
    Mine has the gearbox and a top speed of 6500... I can really slow it down also
    I had thought that there as a compression tap holder ( or some other type) needed.
    Good idea on the thread mill
    Jun 2011
    152
    I think that is the high torque spindle. You could likely rigid tap that, no compression holder needed just get the code right. I would still use a thread mill if you are making several parts. Less problems and is likely faster.
    3/4-10 Carbide Thread Mill
    Richard
  1. are mt3 holders repeatable height holders?
    By neptunier in forum CNC Tooling
    Last Post: 01-01-2017, 01:18 PM
  2. Interesting Observation on ER20 Collet Holders vs. Set Screw Holders
    By EvolveES in forum Tormach Personal CNC Mill
    Last Post: 03-17-2015, 10:45 PM
  3. Need help! Torq cut 22 TLO..
    By Freewheels in forum Bridgeport / Hardinge Mills
    Last Post: 12-15-2009, 06:00 AM
  4. DNC to TOrq Cut 22
    By Drexelracing in forum Bridgeport / Hardinge Mills
    Last Post: 01-16-2009, 11:51 PM
  5. What kind of tool holders for this?
    By petriej in forum Uncategorised MetalWorking Machines
    Last Post: 12-21-2007, 02:15 PM
