586,052 active members*
4,357 visitors online*
Results 1 to 10 of 10
    Jun 2013
    62
    Mitsubishi Meldas M600 data reload
    Hello,
    We are working on a Mitsubishi MV-5C VMC with Mitsuibsihi M600(FCA610MT) controller.
    Machine was working okay 5-6 days ago.
    3 days back machine battery became low and the parameter are now gone.
    We have complete backup of machine in hard and soft copy. There is no hard disk or memory cassette(CBUS#2) in the backside of controller.
    Backup files include:
    USER PARAMETER
    MACHINE PARAMETER
    SYSTEM PARAMETER
    PROGRAM.....etc.
    Now we are trying to reload the data.
    we are able to reload user and machine parameter via RS232 but we are not able to load system parameters.
    After reloading user and machine parameters machine screen shows only X-Axis on Position display and in all the parameter screen.
    Machine Ladder logic is there in the machine.
    Is there special step by step procedure to reload the parameters.....?
    Sep 2017
    139
    Re: Mitsubishi Meldas M600 data reload
    Are the option parameters available ? O parameters ?
    Jun 2013
    62
    Quote Originally Posted by navinbhas View Post
    Thanks for the reply..
    Option Parameters are available, I think so. When you press option settings key inside Maintenance menu. System asks for password. But there is a sceen to view installed option there it shows 6-7 enabled options.
    Sep 2017
    139
    Try disabling edit lock b and c and then load the system parameters.
    Jun 2013
    62
    There is only lock B. I have already tried that lock.
    In manual also it is written that you can take system paramter backup but you can not load back to machine.
    Sent from my SM-G950F using Tapatalk
    Jul 2018
    7
    Hello everone
    i have a cnc machine fulland 2005 model meldas 60 s. I load bacup from casset. But now mocro program gone and machine not change the tool. Could you please help me.
    Jan 2010
    14
    I have same problem and cannot access next axis to enter parameters for Y and Z
    Jun 2013
    62
    Quote Originally Posted by cabbage View Post
    You need machine SRAM Backup then only you can reload the machine. This method is applicable for M600 only. M60 uses ALL1, ALL2,ALL3 files to reload
    Jan 2010
    14
    Quote Originally Posted by jjautomation View Post
    change sram.bak to sram ?
    so can I simply put a parameter list in the hard drive and what folder would I put at?
    Apr 2011
    10
    Hello
    Which password should be input?
    please guide me.
  1. Gildemeister CT40 PLC, Eltropilot EPL2, Data backup/reload
    By abitech74 in forum Controller & Computer Solutions
    Last Post: 11-02-2022, 12:48 PM
  2. How to transfer data using RS232 step by step in mitsubishi meldas 500?
    By godzila in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 12-27-2019, 11:47 AM
  3. Meldas 300 Data Protecting
    By cncsooner in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 02-13-2018, 08:49 PM
  4. Sinumerik 810M Ocrim GFA 160 Data Reload Problem
    By gil2602 in forum SIEMENS -> Sinumerik 810M/810T
    Last Post: 12-31-2014, 02:27 PM
