586,067 active members*
5,346 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > fanuc spindle amplifier low rpm problems
Results 1 to 7 of 7
    Jul 2018
    8
    hello i have fanuc leadwell mcv-550s and i can't get the spindle to run over 200 rpms does anyone know of what would do that my
    ac spindle servo unit is a fanuc ltd A06B-6044-H008 ?
    Aug 2007
    793
    Re: fanuc spindle amplifier low rpm problems
    what is the load (amperage)?
    Jul 2018
    8
    .3 amps the 130hz to 170hz the hz are fluctuating is that normal ?
    15362
    Quote Originally Posted by Tonymc View Post
    What would you use it for below 200 RPM
    Mactec54
    Jul 2018
    8
    I don't want to run it below 200 rpms the machine want go over 200 rpms
    Jul 2018
    8
    a20b-9000-0010 I moved this sensor and it sped up a little bit maybe 300 rpms does anyone now the gap setting
    May 2014
    check spindle amp parameter.
  1. Replies: 1
    Last Post: 08-25-2020, 03:59 PM
  2. Replies: 1
    Last Post: 03-16-2015, 03:02 AM
  3. Replies: 0
    Last Post: 10-03-2012, 01:10 AM
  4. Replies: 4
    Last Post: 09-14-2007, 04:34 PM
  5. Fanuc spindle amplifier alarm 11
    By Eagle View in forum Fanuc
    Last Post: 05-15-2007, 11:10 AM
