586,052 active members*
4,038 visitors online*
    Jul 2018
    14
    turning (not turn-mill) a gear blank
    Hello,
    My part file is a gear blank which i imported from a different software. I would like to turn the gear blank using solidcam 2017. The problem is with the postprocessors for mill-turn, generating lines like G03 X Y L2 . My lathe controlller (GSK CNC) does not understand these L's . I would probably find a suitable postprocessor in the turning list of machines in solidcam, but i can only select turn-mill processors like OKUMALL, DMU80, INTEGREX200. How do i proceed to turn this gear blank? My toolpath has a facing and a profiling operation. Here is a screenshot. https://i.imgur.com/IKWjzbm.png
    Jan 2012
    36
    Re: turning (not turn-mill) a gear blank
    To avoid different issues using a post that isn't designed for your machine, I would highly suggest reaching out to you local SolidCAM reseller. Most of the time they have posts that they can give you that will run the machine without them be customized, which a lot of users prefer.
    Darrin - SolidCAM
    Jul 2018
    14
    Quote Originally Posted by Mikay19 View Post
    Darrin - SolidCAM
    I have gotten the FANUC 2013 turning post and things are better now.
  1. Replies: 0
    Last Post: 04-01-2016, 07:55 PM
  2. looking for a CNC turning shop- small run lots mill turn a plus
    By cnctoolman in forum North America RFQ's
    Last Post: 12-06-2014, 03:33 AM
  3. how to turn mt2 blank soft end arbor on lathe?
    By AchillesGr in forum MetalWork Discussion
    Last Post: 10-03-2012, 10:54 PM
  4. Lathe Turning Copper Bar- HSS blank shape?
    By Odin in forum MetalWork Discussion
    Last Post: 04-06-2012, 02:15 PM
  5. G-Code for turning a AR15 barrel from blank
    By Gtrigg in forum G-Code Programing
    Last Post: 09-11-2011, 06:27 PM
