Usually on the construction site of the curtain wall of windows and doors, we often see some glass plate stacks. Their main application is when some factories cut glass sheets during construction, or when they need to cut small pieces of glass on the spot to facilitate on-site processing.At this time, there is no machine to help, often only rely on manual cutting, how can you do the precision of the manual cutting glass? The following are different glass cutting methods.
For ordinary plate glass: According to the specifications of the glass for installation, it should be combined with the reasonable specification of the boxing glass for centralized cutting. When the sleeve is cut, it should be in the order of "cut big first, and small later, cut width first, and narrow later". The actual size of the doors and windows should be measured before the actual cutting. The actual size of the glass is usually reduced by 3mm from the actual size of the doors and windows to facilitate installation.
Holding the knife is the key action of glass cutting. The thickness of the marking and the size of the force exert a certain influence on the separation of the glass. It is necessary to grasp the size of the force and the direction and angle of the knife. When the knife is cut, the wrist should be straight, the knife bar should be close to the index finger, the plane formed by the knife bar and the cutting direction should not be perpendicular to the knife bar(that is, the angle between the ruler and the knife bar is not a right angle, but the angle between the ruler behind the knifer and the knife bar is the acute angle . ) The acute angle with the tool bar should be slightly tilted backwards.The fingers hold the middle of the arbor should not be too high or too low.The cross-section of the arbor and the ruler should be perpendicular to the cross-section and should not be tilted in or out. If the diamond blade is tilted, it can be cut along with the knife edge position.
When the glass knife moves backward, it can not exert too much force. Just listen to a slight continuous hissing sound on the glass surface. Now there is a fine grain on the glass, and then the glass can be broken by hand.When the hand of narrow glass can't be broken,it can be struck by the glass knife to crack the glass and break it off. If there is remaining residue not broken, the remaining glass can be removed by a steel wire pincer with the soft cloth.
If you cut the longer glass, it's best to cut it out in one breath, do not redraw on the cut lines. If you don't want to do it again, you can cut it on the back, or miss the original 1.5mm. When the knife is firmly held, the angle of the blade and the glass plane must always be consistent when running the moving lines. Do not tilt forward and back, and do not swing left and right. It can only move the force of the whole arm to the end until the end is reached.
According to the glass of different thickness use different specifications of the ruler; if cutting 2 - 3mm thick glass, can use 12mmXl2mm fine wood straight ruler; cut 4 - 6mm thick glass, can use 4mmX 50mm wood ruler; cut width 8 - 12mm glass, the need to use the 5mm X30mm wooden ruler; sometimes can use a ruler according to the operator's habit.When cutting, use wood folding rule or steel tape to measure the size of the glass frame, and then cut the size on the ruler. Consider leaving 3mm neutral and 2mm knife edge. when cutting 2 - 3mm thick glass, the small nail on the ruler can be put on the side of the glass.The glass knife is close to the other end of the ruler, the one hand holds the glass edge that is next to the small nail, and the other hand grasps the edge straight and backward.
The method of cutting 5 - 6mm thick glass is that, in addition to the use of different ruler, the kerosene should be brushed on the cutting edge in advance, and the kerosene will infiltrate into the knife edge after cutting through the glass, which will easily pull off.
When cutting large pieces of glass, because of the large glass area, people can not operate on the ground, so it is necessary for the operator to take off the shoe to cut on the glass surface. Therefore, under the glass (the table surface), a layer of flannelette must be padded to make the glass uniformly compressed. Hold one end of the glass tightly with both hands when pulling off the glass after cutting,and the other end uses the weight of the glass's self weight or the weight of a certain weight.
Through the edge of the case, the hands are evenly pulled down by the hands, and the whole glass can not be broken by carelessness.
The method of cutting the wire glass is basically the same as that of the ordinary flat glass cutting 5 - 6mm thick, but the cutting of the glass is difficult to master because of the uneven cutting of the glass surface. There will be a problem of bending and straight.
