586,103 active members*
3,516 visitors online*
IndustryArena Forum > CNC Electronics > Phase Converters > VFD setup for H.S.D 6.8kw spindle
Results 1 to 13 of 13
    Jun 2006
    198
    I have aquired a few of these spindles and I would like to hook one of these up to my own CNC.
    In order to do this I need a VFD for this, and I have got 2 different ones to try out.
    I have a Control techniques Unidrive UNI2402 and a Hitachi WJ200-150HFE drive to play with.
    I'm trying to test it out on the bench, with a speed potmeter attached, to the Hitachi drive, and it keeps going into overload.
    I have set these paramters for now
    A001 - 00
    A002 - 2
    A003 - 50Hz
    A004 - 400Hz
    A044 - 1
    A082 - 380v
    B012 - 16A
    H003 - 7,5kw (goes in speciel increments so 7,5kw was the closest)
    H004 - 2 poles
    Am I missing something??
    The Unidrive VFD was the one that was placd on the Biesse machine the spindles came of, I cannot get into controlling the speed manually with a Speedpot..
    I have tried most anything already, and I'm looking for some serious help now.
    So if anyone is really good at the one or the other, then please help me out.
    15362
    Re: VFD setup for H.S.D 6.8kw spindle
    Quote Originally Posted by IN-WondeR View Post
    A001 - 00
    A002 - 2
    A003 - 50Hz
    A004 - 400Hz
    A044 - 1
    A082 - 380v
    B012 - 16A
    H004 - 2 poles
    There would be nothing about your spindle that would be using 50Hz so you have something incorrect with that parameter, what are your motor spec's??
    A003=400Hz at 50Hz you have a good chance of damaging your spindle
    Mactec54
    Jun 2006
    198
    A003 is the base frequency of the spindle, as I'm in the EU we run a 50 cycle electricity grid
    Motor specs is as follow
    Voltage: 380v
    Amp: 16A
    RPM @ 200Hz is 12000
    Max RPM @ 400Hz is 24000
    cos: 0,8
    2 pole motor, 3 phase
    15362
    Voltage: 380v
    Amp: 16A
    cos: 0,8
    The base frequency of the spindle is 400Hz look at your spindle spec's you just posted, it has nothing to do with 50Hz electrical grid , unless you are running a 50Hz Ac 3 phase motor and you are not
    You need these ( 2 ) set as well
    A061=400
    A062=200
    Mactec54
    Jun 2006
    198
    Good god man, you are a genious... It never occured to me to run the basefrequency as 400..
    But why would I want to set lower to 200Hz??
    Not it trips the Over Voltage on Decelleration... So I need to play with things, but now the spindle spins up..
    15362
    Just going off what you posted, you posted 200Hz in the spec's, if it is air cooled then this is normal, you can try lower but watch for over heating, all these Spindles have a minimum speed they can safely run at
    Trips on Deceleration because you have not set the deceleration time correct
    Large spindles you need a Braking Resistor if you want to stop fast, if not you would have to adjust the Deceleration Time
    F003=10 By default you would have to make this number larger, without a Braking resistor
    Mactec54
    Mar 2013
    88
    Typically you have to decelerate slower unless you have external braking resistors. Some drives have bigger internal resistors than others for a given HP, not sure about yours
    Jun 2006
    198
    I haven’t mounted a braking resistor yet. I have it on the shelf. Right now it was just a test to get the spindle running. So right now I’m one step closer at getting ATC on my machine.
    Jun 2006
    198
    Braking resistor mounted. Now it can stop in 2 secs flat.
  1. Setup for HY02d223b VFD for 2,2 kw Spindle
    By AllanUrup in forum Spindles / VFD
    Last Post: 03-25-2018, 08:45 AM
  2. Lathe Spindle setup
    By delcon in forum Dynomotion/Kflop/Kanalog
    Last Post: 03-06-2014, 05:12 PM
  3. KG5050 spindle setup
    By dwilliams56 in forum K2CNC
    Last Post: 11-30-2011, 09:31 PM
  4. Suggestions for Spindle setup?
    By Adam Baker in forum Benchtop Machines
    Last Post: 12-23-2009, 06:12 PM
  5. Old lathe spindle setup
    By PIngels in forum Uncategorised MetalWorking Machines
    Last Post: 12-06-2006, 05:15 PM
