586,089 active members*
3,821 visitors online*
    Aug 2006
    47
    Grinder on lathe
    Has anyone tried mounting a small bench grinder on a lath cross slide to use like a toolpost grinder?
    I have seen rotary tools on lathes, angle grinders and various other tools, but never a small bench grinder.
    Is there some reason why this is a bad idea?
    May 2016
    8
    Re: Grinder on lathe
    There may be several problems:
    The height of the disc and the axis of the material if the lathe is small can be different
    If the grinder is small, it may have low power and slow down the entire disc when cutting
    But you can easily try even temporarily fixing the grinder for syport.
    This experiment will not cost you much effort
    sory translator in google
  1. Lathe, Milling,Grinder,CNC
    By endmill1 in forum For Sale Only
    Last Post: 08-13-2016, 03:24 PM
  2. CNC LATHE/OD GRINDER Machinist in Tullahoma, TN
    By MicroTech in forum Employment Opportunity
    Last Post: 01-14-2013, 03:54 PM
  3. sunnen grinder lathe attachment or in block grinder?
    By Goldhunter_2 in forum Uncategorised MetalWorking Machines
    Last Post: 06-28-2011, 01:42 PM
  4. grinder mill lathe combo CNC
    By hesham morsy in forum Vertical Mill, Lathe Project Log
    Last Post: 04-13-2011, 05:53 AM
  5. Crankshaft grinder lathe attachment ??
    By Goldhunter_2 in forum Mechanical Calculations/Engineering Design
    Last Post: 01-01-2010, 09:34 PM
