586,077 active members*
3,591 visitors online*
IndustryArena Forum > CNC Electronics > Gecko Drives > Gecko G202 Power Supply Voltage Calculation Question
Results 1 to 7 of 7
    Aug 2004
    210
    Hello Everyone
    I have 4 G202 Drives and i was reading to make sure i set them up properly
    and I have 4 Chinese 57BYGH115-003
    The manual said 32 * (?mH inductance) = Power Supply Voltage
    From what i found my motor have a Phase Inductance of 9mH
    32 * (?9) = 96V Power Supply
    I am not a expert I might have done something wrong, but that sounds like a lot for them little motor and plus G202 can only do 80V
    I have a 36V, 48V, and a 72V Power supply's That i can use,
    What would be the best choice ???
    Nov 2005
    222
    Re: Gecko G202 Power Supply Voltage Calculation Question
    That would be correct. You could use the 72 volt power supply. You won't get the top speed out of those motors but if it is fast enough then it will be OK. Other that you could look for motors with 5.2mh or less inductance. 5.2 would put you at 72.27 volt motor. I would try the 72 volt supply and see how it goes.
    John
    The best performing motors will have an inductance in the 1.5-2.5mH. Motors with an inductance of 9mH will not perform well at higher speeds.
    Aug 2004
    210
    Thanks a bunch guys
    That's what i will do is run the 72V power supply
    And i will look for new better motors, you look at the torque curve of these ones and it drops faster then Enron stocks hehe
    When you look at the manufacture site, they say 18v to 50v, I am sure running 72v will be fine ??
    Yes, they should be fine.
    Aug 2004
    210
    Right on Thanks aging
    You guys know of a good place to get some alright motors ??
    Nov 2005
    222
    This is the one I used from Automation Technologies. 2.8mH. I'm running it on 48 volt using a Gecko 203V.
    https://www.automationtechnologiesin...lat-381-oz-in/
  1. High voltage power supply, low voltage perihperals
    By feechl in forum CNC Machine Related Electronics
    Last Post: 01-07-2014, 02:12 AM
  2. Power supply step down? Gecko high voltage?
    By bead in forum CNC Machine Related Electronics
    Last Post: 07-06-2010, 04:03 AM
  3. Motor Power Supply (-) voltage question
    By beekeep in forum CNC Machine Related Electronics
    Last Post: 03-21-2010, 06:41 PM
  4. power supply voltage question
    By Monte in forum Stepper Motors / Drives
    Last Post: 03-07-2008, 05:06 AM
  5. Is Gecko 320 tuning supply voltage dependant?
    By digits in forum Gecko Drives
    Last Post: 06-19-2007, 12:59 PM
