586,103 active members*
3,466 visitors online*
    Doosan DNM 5700
    Can someone compare Doosan DNM 5700 with DMG CMX800v?
    Same equipment!
    12k rpm
    renishaw
    through spindle coolant
    DMG have direct measuring system in standard, DOOSAN dont have.
    Dec 2010
    141
    Re: Doosan DNM 5700
    The Doosan is a 41x22" machine and the DMG is a 31x22" machine. The Doosan is probably lower cost and has a Fanuc controller. I'd take the Doosan, because I have a great dealer and I like the Fanuc control.
    Re: Doosan DNM 5700
    Lets say, size doesn't matter. What would you chose?
    I realy like DNM with siemens 828d.
    Is worth to pay 14k more for smaller DMG? (siemend 840d)
    Feb 2013
    788
    Re: Doosan DNM 5700
    How about "the best of both worlds"
    A DNM 5700 with a Siemens Control
    Doosan has recently licensed the use of Siemens controls on their machines.
    There currently is a slight lead-time of around 6 months after order. (that time should decrease as we progress)
    You need no reason to compromise...
    Doosan Service Technician
    [email protected] O:973-618-2461 M:973-803-9479
    Jul 2016
    Re: Doosan DNM 5700
    Late reply, but here's my take.
    DNM5700 - X & Y movement is the table moving on roller guides.
    CMX800 - X movement is the table moving on roller guides, Y movement is a roller guide Bridge style (basically the Y axis is moving over the table & Z axis is attached to Y).
    I have heard nothing but horrors about DMG Mori's Y Bridge style movement on the older Ecomills. The Y axis begins to sag over time. The CMX is basically the Ecomill v2. They "fixed" this issue by adding tensioning rods on the casting to keep pressure on the head & you can also adjust it if it begins to sag over time.
    Where the CMX wins is floor space (due to the bridge style Y axis) & UNusable table space. CMX's have abnormally large tables, allowing you to mount a rotary axis without losing hardly any X axis travel. So, if you are mounting a rotary axis, you will end up with roughly the same amount of working travel on both machines.
    Where the Doosan wins is rigidity & standard oil chilled spindles (CMX has a grease packed spindle, not chilled). I personally own a DNM 5700. While it has had its issues, I would buy another.
  1. DMG CMX800V vs DOOSAN DNM 5700
    By Greegor in forum Want To Buy...Need help!
    Last Post: 07-29-2018, 10:01 AM
  2. Doosan vnm 400
    By mattlynx in forum Uncategorised MetalWorking Machines
    Last Post: 05-25-2014, 10:29 AM
  3. Doosan DVC 500
    By Jay H in forum Daewoo/Doosan
    Last Post: 10-03-2008, 03:32 PM
