586,082 active members*
3,593 visitors online*
Results 1 to 6 of 6
    PMDX-109 with UCCNC UB1
    Is it possible to use a PMDX-109 on either the 4th or 5th ports on the UB1 (need more outputs) or is a better solution the UD1?
    Re: PMDX-109 with UCCNC UB1
    Adding a UD1 would be completely different then plugging a relay board in?
    Not sure what the goal is. Do you need more outputs, or just relays?
    I'm using a board like this: https://www.amazon.com/dp/B07BLWZQZB...ing=UTF8&psc=1
    You can buy 3, and have two spares for less than half the cost of the PMDX-109
    Thanks for the reply Gerry!
    I've got two of those same boards. I trigger the relays via the outputs on the UB1, but am limited by the number of outputs available.
    Thoughts on the best way to utilize the 16 relays I've got on both boards??
    My mistake on my previous reply. The PMDX-109 will NOT work on port 4 and 5 of the UB-1.
    You are limited by the design of the UC300ETH, because ports 4 and 5 only have 4 outputs each. You could use a UD-1, or two bidirectional cards like a C10 maybe?
    What are you doing that requires 16 relays?
    I think the C72, which is a new breakout board that will do what you are asking for:
    https://cnc4pc.com/c76-uc300-multifunction-board.html
    In addition to having all the features, it can easily expand using all kinds of relay or breakout boards.
    Note that when you connect an expansion board, like the M26D
    https://cnc4pc.com/m26d-12-relay-expansion-board.html
    You are not just connecting power and the signals, but also the enable line, so if e-stop is pressed or the system faults in any way all expansion boards are also disabled.
    Arturo Duncan
    https://cnc4pc.com
    I've got pneumatics set up for a ATC spindle, vacuum table (4 zones), etc. etc.
  1. Replies: 1
    Last Post: 12-14-2016, 03:10 AM
  2. PMDX 122 Rev D
    By b'nb in forum Controller Cards
    Last Post: 01-27-2015, 05:09 PM
  3. Replies: 0
    Last Post: 02-26-2014, 03:41 AM
  4. Having Issues w/ PMDX-126 PMDX-134 and Ethernet Smooth Stepper
    By Hurshy in forum Community Club House
    Last Post: 08-27-2013, 01:20 PM
  5. PMDX-125 or PMDX-132 for Geckos?
    By Nivea in forum Gecko Drives
    Last Post: 03-24-2010, 08:18 AM
