586,119 active members*
3,556 visitors online*
IndustryArena Forum > MetalWorking Machines > Cincinnati CNC > cincinnati milacron arrow 500 acramatic a2100e
    Apr 2017
    12
    Good companions, I use English translator, we have sold this machine and the 4 axis has been disassembled because we were not interested, the control gave an error because I could not find the A axis encoder (4th axis), I have disconnected it from the control and now the error that appears to me is 44-43, the control tells me that I must make a plug to make a loop, I do not have an electrical diagram of this machine, you can help me, the servos are BSD4.Thank you.
    Apr 2017
    12
    Re: cincinnati milacron arrow 500 acramatic a2100e
    Dec 2006
    584
    On the pendent you can to select to REMOVE the A axis but you may need a loop back connector to jumper things like MOTOR OVERTEMP and the motor resolver feedback. YOU NEED TO GET THE ELECTRICAL PRINTS FOR YOUR MACHINE!!!!
    MIKE CNC Machine Services INC | Cincinnati Milacron MachinesCNC Machine Services
    Apr 2017
    12
    Thanks for your answer the diagram I need is the 91202971
    Sep 2010
    1765
    I believe all loop back plugs are the same. Email me and I will remember to send you how to make one. [email protected]
    Sent from my SM-G900V using Tapatalk
  1. Cincinnati milacron arrow 500
    By shmoo in forum Uncategorised MetalWorking Machines
    Last Post: 12-10-2014, 10:33 PM
  2. Cincinnati milacron arrow 500 to pc
    By gazzaa in forum Want To Buy...Need help!
    Last Post: 01-20-2012, 07:30 PM
  3. Replies: 3
    Last Post: 09-05-2011, 01:19 PM
  4. Cincinnati milacron 750 arrow error msg
    By A1 roper in forum CNC Machining Centers
    Last Post: 02-11-2011, 02:24 PM
  5. cincinnati milacron arrow 750
    By kevmor in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 04-06-2009, 08:26 PM
