586,035 active members*
3,712 visitors online*
Results 1 to 6 of 6
    Jan 2018
    17
    Change keyboard key mapping
    Hello
    Using Mach3 I'm trying to edit the keymappings of my keyboard without much success.
    eg. I'm looking to map the 0 key on the numerical keypad to Estop.
    Using Windows10 Home this is what i'm doing but it's not working:
    Config > Ports Pins > Input Signals > EStop > Hotkey > click 0 (45) & check Emulated
    Config > System Hotkeys > enter OEM code (1003??) in pin 5 (from Ports Pins??)
    Thanks for your help
    Re: Change keyboard key mapping
    Keyboard emulation requires the motion controller you are using to support it, and many don't.
    Jan 2018
    17
    Ok, i'm not sure i understand - so keyboard input on my computer goes directly to the controller?
    Why can't i just control Mach3 with the keyboard - i mean other functions of Mach3 are controlled this way eg Alt-R is Cycle start? Apologies for my ignorance on this.
    No.
    But the activation of "emulated" inputs are controlled by the motion controller. And most motion controllers do not support emulated inputs.
    You can.
    Hotkeys for onscreen buttons are added using a screen editor, and are saved in the screen .set file. You can set any keyboard key you want for any buttons on the screen.
    Jan 2018
    17
    Thanks for your help.
    This led to the next problem i was having - i ran Mach3Screen & there is no indication about how i change hotkeys or anything else really.
    So i tried MachScreen & that seems to work a bit better.
    Phew - thanks again.
    I've been using screen4 for the last 10 years, and maybe only looked at Mach3screen once or twice prior to that. Screen 4 has a checkbox to assign hotkeys, which is very straightforward.
  1. 4th axis mapping
    By vmax549 in forum UCCNC Control Software
    Last Post: 09-02-2016, 09:38 PM
  2. mapping direction
    By joo-o in forum Solidworks
    Last Post: 04-18-2015, 11:03 AM
  3. Replies: 2
    Last Post: 11-20-2013, 03:24 AM
  4. Replies: 1
    Last Post: 04-21-2010, 05:24 AM
  5. Joystick to Keyboard mapping software
    By dwwright in forum Uncategorised CAM Discussion
    Last Post: 12-26-2007, 02:03 AM
