586,075 active members*
3,958 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > How to set up center of rotation on Horizontal Mill
Results 1 to 8 of 8
    Aug 2009
    37
    Hi guys,
    I am in need of some help this morning. We have several okuma horizontal MA600-HB machines and the old programmer didn't know how to program from center of rotation. So his programs are done with a lot of formulas to figure out Z at different rotations. I would like to start programming from center of rotation so that I don't have to figure that stuff out.
    Does anyone know of a way to set up the machine so I can set my fixture offsets from center of Rotation?
    Thank you,
    Todd Saladyga
    Apr 2016
    74
    Re: How to set up center of rotation on Horizontal Mill
    find how far it is from the spindle to the center of your pallet(should be on the machine or the book. and measure you tools overall length minus the gap that exists between the holder and spindle face when the tool is in the spindle. use that for you tlo.
    Jun 2015
    4154
    hi something seems out of place : such good equipments without programming skills / if i may, what happened ?
    ma600-hb = [ vmc + 4th axis + turn_cut_option ] + 90* rotation
    ... or
    ma600-hb = live tools lathe + indexing chuck
    kindly
    Apr 2016
    74
    deadly kitten is the okuma man. kindly
    Jun 2015
    4154
    hello again, let's try to make things work : share a photo with your fixture, describe the existing approach, and what you don't like about it, and how you wish to change it pls be specific just a bit
    i am sorry, i can't understand exactly what you wish for :
    ... do you rotate the 4th axis, and you wish to reposition? to much math involved ?
    ... all programs have Z0 in the center of the 4th axis, or Z origin is relative to table center ?
    ... tombstones ? complex fixture ?
    kindly
    ps : hi skywalker
    Aug 2009
    37
    Quote Originally Posted by skywalker4 View Post
    I was able to figure it out guys. I found center of table like Skywalker4 suggested, created offset H10 for center of rotation and called the other offsets from that point.
    So basically we are running two parts per tombstone and this is how I was able to achieve it.
    OSET1
    (**** FIXTURE ZERO ****)
    (*******SETS CENTER OF ROTATION*****)
    VZOFX[10]=0.0
    VZOFY[10]=0.0
    VZOFZ[10]=-12.509
    VZOFB[10]=0
    RTS
    OSET2
    VC110=1(SETS ACTIVE PALLET)
    (*******PART ZERO**********)
    (*** B0 COORDINATES *** )
    VZOFX[20]=VZOFX[10]+7.000
    VZOFY[20]=VZOFY[10]+14.57
    VZOFZ[20]=VZOFZ[10]+5.26
    VZOFB[20]=0
    VZOFX[30]=VZOFX[10]-7.000
    VZOFY[30]=VZOFY[10]+14.57
    VZOFZ[30]=VZOFZ[10]+5.26
    VZOFB[20]=0
    RTS
    OSET3
    (*** B180 COORDINATES *** )
    VZOFX[40]=VZOFX[10]-7.000
    VZOFY[40]=VZOFY[10]+14.57
    VZOFZ[40]=VZOFZ[10]-4.19
    VZOFB[40]=180
    VZOFX[50]=VZOFX[10]+7.000
    VZOFY[50]=VZOFY[10]+14.57
    VZOFZ[50]=VZOFZ[10]-4.19
    VZOFB[50]=180
    RTS
    Jun 2015
    4154
    hello tsaladyga, there are different ways to put the origin
    using a system variable is ok, especially if you declare the origin without being near the cnc
    instead of :
    Code:
    OSET2
    VZOFB[20]=0
    VZOFB[20]=0
    RTS
    you may use this shorter code:
    Code:
        NOEX VC110 = 1
        G15 H10
        G11 X+7 Y+14.57 Z+5.26 ( coordinate system conversion )
        // cutting with actual corections
        G10
        G11 X-7 Y+14.57 Z+5.26 ( coordinate system conversion )
        G10
    however, even so, it is too much code; also this is possible :
    Code:
    O****
        NOEX VC110 = 1 ( active pallet )
        NOEX VZOFX [ 30 ] = +7 VZOFY [ 20 ] = +14.57 VZOFZ [ 20 ] = +5.26 VZOFB [ 20 ] = 0
        NOEX VZOFX [ 30 ] = -7 VZOFY [ 30 ] = +14.57 VZOFZ [ 30 ] = +5.26 VZOFB [ 30 ] = 0
    RTS
    this last sample requires a determined cnc, thus the origin at the middle of the table is no longer declared inside G15H10, but as the origin of the abso-encoders
    and the code can be futher enhanced, so to reduce future edit time :
    Code:
    O****
        NOEX VZOFX [ 20 ] = +7 VZOFY [ 20 ] = +14.57 VZOFZ [ 20 ] = +5.26 VZOFB [ 20 ] = 0
        CALL OCOPY LV01 = 20 LV02 = 30
        NOEX VZOFX [ 30 ] = - VZOFX [ 30 ]
    RTS
    Code:
    OCOPY ( copy work coordinate system; LV01 : source , LV02 : target )
        NOEX VZOFX [ LV02 ] = VZOFX [ LV01 ]
        NOEX VZOFY [ LV02 ] = VZOFY [ LV01 ]
        NOEX VZOFZ [ LV02 ] = VZOFZ [ LV01 ]
        NOEX VZOFB [ LV02 ] = VZOFB [ LV01 ]
    RTS
    kindly
    Jun 2015
    4154
    code from this post is equivalent with code from post #6
    requirements : ocopy soubroutine + shifting the abso-encoder origins ( grid shifting )
    * if you have allready some soubroutine, just add 1 more
    * shifting the encoder origin comes with some advantages :
    ... origins will no longer be floating, but relative to an absolute position ( real palpable position )
    ... tool offsets and fixture coordinates may be declared by using measuring instruments ( calipers, indicators, etc ) with a precision < 0.1
    ... alows checking how much the cnc components have moved overtime ( a heavy table may tilt, maybe will move down, towards the foundation )
    ... alows declaring the origins without being near the cnc
    ... sync the machine with the cam and with the external tool measuring unit
    *etc
    kindly
    Code:
        NOEX VZOFX [ 40 ] = -7 VZOFY [ 40 ] = +14.57 VZOFZ [ 40 ] = -4.19 VZOFB [ 40 ] = 180
        CALL OCOPY LV01 = 40 LV02 = 50
        NOEX VZOFX [ 50 ] = - VZOFX [ 50 ]
  1. X axis off from center of pallet rotation
    By CNC-FLOW in forum Toyoda
    Last Post: 09-21-2016, 06:07 PM
  2. Horizontal Machining Center - Ovality in Job
    By M.RISHIKESH in forum Uncategorised MetalWorking Machines
    Last Post: 08-18-2015, 07:06 PM
  3. Horizontal vs Vertical Machining Center
    By B.Reilly in forum Uncategorised MetalWorking Machines
    Last Post: 07-27-2011, 08:09 PM
  4. CNC Machining Center- both Vertical and Horizontal - MI
    By MachiningJobs in forum Employment Opportunity
    Last Post: 04-04-2011, 10:49 PM
