586,069 active members*
3,515 visitors online*
IndustryArena Forum > CAM Software > EnRoute > Editing post processor
    Apr 2018
    I have Enroute 6 and a Shopsabre cnc table cutting with oxy acetylene. I have a basic understanding of programming (ok maybe less than that). What I would like to do is edit the post processor to tweak a few things that seem to be oxy fuel specific which the program is apparently not designed for. But I have to work with what I have. I'm finding that when I create a cut path and add in the feed rate it does not transfer to my G code in the WinCNC program. I have to go in and edit the G code manually, adding the feed rate and a Z0 after the second line of EVERY PIERCE. So when I am cutting a full sheet this takes a long time. I also have to add M61 (custom oxy on code) and M62 (custom code that turns off the oxy solenoid and raises Z) to the end of every cut. Since it seems like a pretty basic repeating pattern I'm thinking there must be a way to program it in. Does this seem like a WinCNC problem or Enroute?
    Hopefully someone has some insight
    thanks
    Apr 2018
    Re: Editing post processor
    Shopsabre tech support was able to help me out. All I had to do was copy some .ini file into another folder. Works great now
  1. Editing a Post Processor
    By tjb1 in forum Mastercam
    Last Post: 07-01-2016, 09:09 AM
  2. Post processor editing
    By Nadroj88 in forum Post Processors for MC
    Last Post: 04-09-2012, 12:22 PM
  3. Post Processor Editing
    By rrbmachining in forum CamWorks
    Last Post: 06-23-2010, 02:27 PM
  4. POST PROCESSOR EDITING
    By blmmdes in forum Hypermill
    Last Post: 05-08-2008, 06:27 PM
