https://www.automationtechnologiesin...or-and-driver/
Panel operation parameter setting:
https://youtu.be/2zPA8Sy_01I
https://youtu.be/CwKvtFlH2YM
https://youtu.be/Nx1bsaK9DsU
A: KL-2200_BLM Brushless Motor and Driver kit, 220VAC,:
1: KL-2200_BLM Brushless Motor : 2200W (3.0HP) / 6000RPM/ 220VAC, Single phase , up to 6000RPM Brushless Motor, Shaft Size: 18mm
2: KL-2260_BLM Brushless Motor Driver , AC 220VAC input for 2200W (3HP)
B: KL-1100_BLM Brushless Motor and Driver kit 220VAC,:
1: KL-1100_BLM Brushless Motor : 1100W (1.5HP) / 8000RPM/ 220VAC,Single phase , up to 8000RPM Brushless Motor, Shaft Size: 15mm
2: KL-1100_BLM Brushless Motor Driver, AC 220VAC input
One Year parts Warranty
Panel Control:
1?Run ---------- Bottom left Key
2?STOP------------Top Middle Key
3?Increase ---- --- Top Right Key
4?Decrease ------- Botton Right Key
5: Configure ------ Top Left
Exchange between panel and 0~10v analog A: ?Panel operation parameter setting Panel speed settings are as follows three parameters, after the restart into the panel speed mode panel operation mode: (FN000 = d0012, Fn001 = 1, FN010 = 36,FN147=1 Displays the current panel setup speed, After set this, power off and Power on)
Analog speed mode: ( FN000 = d0005, Fn001 = 0,FN010 = 3 Displays the actual motor speed, After set this power off and Power on)
0-10v Analog Speed Setting :
The following three parameters, after the restart into the analog speed and use the port to start and reverse speed
<Press the “Mode” key when you see FN000, then press the “Set” key , you will see d0012, then press the “down” key to see d0005 ,then press the “set ”key>
Fn001 = 0
<now press the “mode”key when you see Fn000 then press the “Up”key to Fn001 then press the “set” key , you will see 1 press the “down” key to 0, then press the “set “key>
FN010 = 3
Displays the actual motor speed , change FN147=0
<then now press the “mode”key when you see Fn000 then press the “Up”key to Fn010 then press the “set” key , you will see 36 press the “down” key to 3, then press the “set “key>
Step by Step, then will change into 0~10V use
FN220: 1040 ( 0 to 5 VDC Control)
FN220: 520 ( 0 to 10 VDC control)
